TBS-Blindscan Error with both TBS6922SE or TBS6982 cards
Postby Bloomingtom » Sat Sep 12, 2015 3:46 am
About a year ago I purchased a TBS6922SE PCIe satellite card for my Windows 8.1 64bit computer. I connected the TBS6922SE PCIe satellite card to my satellite dish and was able to perform a Blind scan and receive satellite signals. A few months later I started getting an error message when the blindscan utility or any other satellite program was launched. I tried both the original drivers that came with the TBS card and currently have the latest drivers for TBS6922SE PCIe satellite card installed that I downloaded from this site. The Error Message I get when I launch the TBS Blindscan "TBS-Blindscan Error: KSPROPERTY_BDA_TBSACCESS Interface not supported!" (See attachment). I have spent weeks on this and tried everything I could think of including uninstalling all TBS satellite and all other Satellite software with no luck. I even reinstalled the Windows 8.1 64bit operating system and came to the conclusion I had a bad TBS6922SE PCIe satellite card. I then purchased a new TBS6982 PCIe satellite card. I get the same Error Message I get when I launch the TBS Blindscan or any other satellite software: "TBS-Blindscan Error: KSPROPERTY_BDA_TBSACCESS Interface not supported!" (See attachment). I have even moved the satellite card into a different PCIe slot and only using One card at a time. The Message indicates a problem with the BDA driver. Does anyone know if there is another BDA driver I can try and where I can get it from? Does anyone have any ideas on how I can get either my TBS6922SE or TBS6982 PCIe satellite cards working. Any help would be appreciated. -Tom
Bloomingtom
Re: TBS-Blindscan Error with both TBS6922SE or TBS6982 cards
Postby Bloomingtom » Sat Sep 12, 2015 4:00 am
Forgot to mention that the TBS satellite cards show up correctly in device manager so the drivers appear to be installed correctly.
Bloomingtom
Postby Alfredo » Mon Sep 21, 2015 11:13 am
Can you watch TV? If the answer is yes, then it's no problem of the card.
Try to put the TV card in another PC.
Cheers
Alfredo
Postby fumbduck » Mon Nov 16, 2015 3:56 pm
I get the same error Tom
but fortunately it still performs the blindscan after clicking the error away
fumbduck
Postby steven » Mon Nov 16, 2015 5:06 pm
fumbduck Wrote:I get the same error Tom
Hi fumbduck
which version of Blind scan tool you are using ? please have a try with our latest one :
http://www.tbsdtv.com/download/document ... _tools.zip
Postby fumbduck » Mon Nov 16, 2015 8:57 pm
Thanks steven
that version seems fine, no errors reported
shame there's still no option to use a linear lnb type apart from Universal.
here in Australia we use 10700 lnb's
so I am forced to use the circular lnb type so I can adjust the LO to 10700
fumbduck
