Windows Media Center EPG
Postby JohnStevens » Tue Sep 08, 2015 5:01 pm
I am not getting any information for UK Freeview HD Channels
JohnStevens
Re: Windows Media Center EPG
Postby Pixelz » Thu Nov 26, 2015 9:02 pm
Windows 7 Media Centre supports both in-band over-the-air EPG (7 days of data) and EPG data downloaded from the internet (14 days of data). However, the in-band EPG data for UK Freeview HD channels is encoded (to prevent casual copying) and Media Centre does not handle this encoding. Therefore if there are any problems downloading the internet EPG data, then only SD channels will have their EPG data populated. Check the Media Centre logs for any EPG download errors, and also check Tasks/Settings/TV/Guide/Edit Channels/Edit Listings to ensure your scanned HD channel names match the corresponding EPG channel names. Hope this helps.
Pixelz
