Maximum amount of /dev/dvb devices in MOI+
Postby joshi » Thu Aug 20, 2015 4:44 pm
I'm into little experiment here (I hope things like this are not mentioned in Geneva convention):
Long story short - I connected PCIe splitter to MOI+ and plugged 3 different TBS DVB-S2 cards in it: 6991, 6991SE and 6985, totaling at 8 logical adapters.
All 8 of them show up during startup both on LCD:
and in dmesg:
But in /dev/dvb there are only 4 adapters, no matter whether I put 2 or all 3 cards in:
The strangest moment is that UI is stuck on 6 adapters (I booted up with only 6991SE and 6985 at first):
What I'm interested in:
Is 4 adapter limit somehow hard-coded intentionally for MOI+ or there is a way of removing this limitation?
If it is hard-coded, what is this limit for MOI Pro? 8 adapters?
joshi
Re: Maximum amount of /dev/dvb devices in MOI+
Postby xiaocao » Thu Aug 20, 2015 5:51 pm
hi,
please add this context in /etc/mdev.conf
/dev/dvb4.frontend0 0:0 660 =/dev/dvb/adapter4/frontend0
/dev/dvb4.demux0 0:0 660 =/dev/dvb/adapter4/demux0
/dev/dvb4.dvr0 0:0 660 =/dev/dvb/adapter4/dvr0
/dev/dvb4.ca0 0:0 660 =/dev/dvb/adapter4/ca0
/dev/dvb4.net0 0:0 660 =/dev/dvb/adapter4/net0
/dev/dvb5.frontend0 0:0 660 =dvb/adapter5/frontend0
/dev/dvb5.demux0 0:0 660 =dvb/adapter5/demux0
/dev/dvb5.dvr0 0:0 660 =dvb/adapter5/dvr0
/dev/dvb5.ca0 0:0 660 =dvb/adapter5/ca0
/dev/dvb5.net0 0:0 660 =dvb/adapter5/net0
/dev/dvb6.frontend0 0:0 660 =dvb/adapter6/frontend0
/dev/dvb6.demux0 0:0 660 =dvb/adapter6/demux0
/dev/dvb6.dvr0 0:0 660 =dvb/adapter6/dvr0
/dev/dvb6.ca0 0:0 660 =dvb/adapter6/ca0
/dev/dvb6.net0 0:0 660 =dvb/adapter6/net0
/dev/dvb7.frontend0 0:0 660 =dvb/adapter7/frontend0
/dev/dvb7.demux0 0:0 660 =dvb/adapter7/demux0
/dev/dvb7.dvr0 0:0 660 =dvb/adapter7/dvr0
/dev/dvb7.ca0 0:0 660 =dvb/adapter7/ca0
/dev/dvb7.net0 0:0 660 =dvb/adapter7/net0
best regards!
xiaocao
Postby joshi » Thu Aug 20, 2015 7:30 pm
Thanks a lot, xiaocao!
I will try this in the evening and report on results. This MOI+ box looks more and more attractive as time passes.
joshi
Postby joshi » Fri Aug 21, 2015 3:35 am
Unfortunately no result:
[root@moi /]# ls /dev/dvb -la
total 12
drwxr-xr-x    1 root     root          2048 Jun 15  2001 .
drwxr-xr-x    1 root     root          2048 Jun 18  2001 ..
drwxr-xr-x    1 root     root          2048 Jun 15  2001 adapter0
drwxr-xr-x    1 root     root          2048 Jun 15  2001 adapter1
drwxr-xr-x    1 root     root          2048 Jun 15  2001 adapter2
drwxr-xr-x    1 root     root          2048 Jun 15  2001 adapter3
[root@moi /]#
at the same time dmesg:
TurboSight TBS 6991SE Frontend Attaching...
TurboSight TBS6991SE DVB-S2 card port1 MAC=00:22:ab:d1:1c:b9
tbsci: Initializing TBS 6991SE CI 1 slot
tbsci: Adapter 1 CI slot initialized
DVB: registering adapter 1 frontend 0 (TurboSight TBS 6991SE DVBS/S2 frontend)...
DVB: registering new adapter (SAA716x dvb adapter)
TurboSight TBS 6991 Frontend Attaching...
TurboSight TBS6991 DVB-S2 card port0 MAC=00:22:ab:d1:01:4e
tbsci: Initializing TBS 6991 v13 CI 0 slot
tbsci: Adapter 2 CI slot initialized
DVB: registering adapter 2 frontend 0 (TurboSight TBS 6991 DVBS/S2 frontend)...
TurboSight TBS6991 DVB-S2 card port1 MAC=00:22:ab:d1:01:4f
tbsci: Initializing TBS 6991 v13 CI 1 slot
tbsci: Adapter 3 CI slot initialized
DVB: registering adapter 3 frontend 0 (TurboSight TBS 6991 DVBS/S2 frontend)...
TurboSight TBS 6985 Frontend Attaching...
TurboSight TBS6985 DVB-S2 card port0 MAC=00:22:ab:90:9c:e8
DVB: registering adapter 4 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
TurboSight TBS6985 DVB-S2 card port1 MAC=00:22:ab:90:9c:e9
DVB: registering adapter 5 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
TurboSight TBS6985 DVB-S2 card port2 MAC=00:22:ab:90:9c:ea
DVB: registering adapter 6 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
TurboSight TBS6985 DVB-S2 card port3 MAC=00:22:ab:90:9c:eb
DVB: registering adapter 7 frontend 0 (TurboSight TBS 6985 DVBS/S2 frontend)...
joshi
Postby xiaocao » Fri Aug 21, 2015 11:40 am
hi ,
it maybe need to change kernel source ,it's very complex.
if you want to insert two cards , i suggest you to buy moi pro , moi pro support 2 pci cards.
best regards!
xiaocao
Postby joshi » Fri Aug 21, 2015 3:05 pm
Well, it's not 2, more like 4 cards. It seems a bit of waste of CPU, when you look at "top" - 5-6% per transponder. And - its a pure scientific interest. I contacted support and they are looking into this. It seems like this limitation is not intentional, more like unexpected side-effect.
joshi
Postby Naomaruta » Fri Sep 04, 2015 10:40 am
sbobet เล่นไม่ได้
Naomaruta
Postby joshi » Sat Sep 26, 2015 1:01 am
Actually, no answer since then.
joshi
Postby costan » Wed Oct 28, 2015 7:57 am
When booting with all the stuff, how many /dev/dvb<n> devices you have?
The /dev/dvb/adapter<n> folders just host symlinks to the /dev/dvb<n>.* logical device names.
Have a look, it might be just a matter of creating a bunch of symlinks.
Ciao,
A.
costan
Postby joshi » Thu Nov 12, 2015 6:39 am
Thanks, costan, I will actually try this tomorrow and post results here.
joshi
Return to MOI+
