Moi Pro Urgent Question(solved)
Postby iptvprivado » Thu Aug 13, 2015 9:22 am
Hello mates, i have a question for you please.
Is TBS6905 compatible with MOI PRO?
I have a MOI PRO with a TBS6905 inside, but i can´t see the TBS6905 in TvHeadEnd.
Do i need to install any driver on TSB Moi Pro?
What is the problem?
iptvprivado
Re: Moi Pro Urgent Question
Postby steven » Thu Aug 13, 2015 3:36 pm
Hi iptvprivado
you can use TBS6905 with MOIPro already installed the driver,but good advice is to use special quad card made for MOIPro(TBS6904) which is better than TBS6905.
And for your issue.from MOIPro webpage can you see the TBS6905 tuner? dvblast scan page. make sure that there is no other application is using TBS6905.
Postby iptvprivado » Thu Aug 13, 2015 8:34 pm
Solved.
I forgot to update the MOI PRO to 1.0.0.8
Thanks "steven"
iptvprivado
Return to MOI Pro
