tbs6904
tbs6904
Postby hatster » Sat Aug 08, 2015 9:50 pm
hi,
How come there is no reference to the tbs6904 card anywhere ?
I bought a moi pro with 2x quad s2 cards, however the moi pro is too unstable for my needs and i want to use the cards in a ubuntu server. I have put them into a hp proliant g5, and installed ubuntu, and then drivers, but all tuners always report no signal on every mux which i know is not true.
Does anyone have a clue ? are the 6904 cards proprietary in some way only for the moi pro ?
Thanks.
hatster
Re: tbs6904
Postby crazycat » Sun Aug 09, 2015 6:31 am
tbs linux drivers support 6904
Re: tbs6904
Postby hatster » Sun Aug 09, 2015 7:14 pm
thanks - i see the driver loads but all frequencies on all ports say no signal, this is definately not true. does anyone else have this working in ubuntu ? or any other linux ?
thanks,
hatster
Re: tbs6904
Postby steven » Mon Aug 10, 2015 3:57 pm
Hi hatster
This card is special make for MOIPro ,but it works in PC too. Is TBS6904 works wok with MOIPro?
and which application you are using with TBS6904?maybe it is the config issue.
Re: tbs6904
Postby hatster » Tue Aug 11, 2015 4:15 am
thanks.
Were using ubuntu, tried latest version, and also 12 but same result. trying with tvheadend, and also scan direct from shell but both produce no signal on all frequencies / transponders...
hatster
Re: tbs6904
Postby steven » Tue Aug 11, 2015 4:38 pm
Hi hatster
First, For MOIPro with TBS6904 you said is not stable can you give us more detail information about this.And please have a try using our latest firmware:
http://sourceforge.net/projects/moipro/ ... p/download
Second,If TBS6904 works ok with MOIPro this card should be ok.do you have tested dvblast and can you share your dvblast setting?or you can send your detail
information to our support and set a remote connection we will help you have a remote check where the problem is
Re: tbs6904
Postby hatster » Wed Aug 19, 2015 4:47 am
the 6904 definately does not work under ubuntu, it shows up but cannot find any signal, ever !
The 6905 works ;)
It would be nice if I could use the 6904 but I guess Ill have to order some more 6905.
hatster
Re: tbs6904
Postby steven » Wed Aug 19, 2015 3:33 pm
Hi hatster
Can you set a remote connection of your ubuntu PC so we can have a remote check.
you can send your remote connection information to my email steven#tbsdtv.com
Re: tbs6904
Postby hatster » Wed Aug 19, 2015 4:15 pm
I wont be able to do this just yet as the system is now in production. I will come back to you in a week or so.
thanks,
hatster
Re: tbs6904
Postby steven » Thu Aug 20, 2015 11:19 am
Hi hatster
Ok we will continue focus on this issue.
