Problem with TBS6983 upper KU Band in Transedit , DVBViewer
Postby assemblersat » Thu Aug 06, 2015 10:40 pm
to insert programs into DVBViewer i scan the whole Satband (lower und upper KU Band) with EBSpro .the produced "ini File"
i scan with Transedit to extract all programs and insert selected programs to DVBViewer.
more often it happens that Transedit find no programs at upper ku band and mar this Transponders with "X"
but all Transponders have a good signal everytime .
DVB Viwer also often not display programs in upper KU Band .
to solve this problem i must start EBSpro and select one of the upper KUBand transponders
after this "activation by EBSpro" DVBViewer and Transedit work good
i use NO DiSEqC, satcable is new, i test it with different LNCs
NO problems i have with EBSpro Crazyscan and TSReader light
assemblersat
Re: Problem with TBS6983 upper KU Band in Transedit , DVBVie
Postby steven » Fri Aug 07, 2015 2:50 pm
hi assemblersat
Just contact with DVBView maybe you can have a try forward this information to DVBView forum.
And they are on holiday when he come back he will have a check.
Postby assemblersat » Fri Aug 07, 2015 5:18 pm
hello steven
i contact DVBViewer Mr.Hackbart he say to me that he and the DVBViewer technical team have no idea to this problem
also i post this problem in DVBViewer forum since 1 month but also negatiiv.
you also think this is a software not hardware issue?
assemblersat
Postby steven » Mon Aug 10, 2015 5:35 pm
Hi assemblersat
As other player is ok ,so hardware should be ok. Maybe some compatiable issue with DVBView.
we will have a check with our driver too. and give you an reply later
Postby assemblersat » Tue Aug 11, 2015 5:59 am
Hello Steven
please look at your test also on "unusual Satellites " 7East,10East.16East,23,5East ... with different FECs and Sympolrates SCPC and MCPC Transponders
i use the configuration with EBSpro/Transedit and DVBViewer most of time for DX (but only for TV Feeds ,all other Signals for example Data Channels are sorted out)
kind regards
alexander
assemblersat
