Missing metal cover on tuner chip
Postby willyp » Wed Jul 22, 2015 11:46 am
I have received my 6983 card from buydvb and it's missing the metal cover over the tuner chip.
On every photo I've seen online they were on.
Is it just mine?
It's V20
willyp
Re: Missing metal cover on tuner chip
Postby steven » Thu Jul 23, 2015 4:59 pm
Hi willyp
Yea,remove the metal shield even help to improve the sensitivity
so we remove it ,It is ok,Please do not worry about this. :)
Postby willyp » Thu Jul 23, 2015 7:27 pm
Thank you for the answer.
That's OK then.
But is it safe for the hard drive?
Do I always need to have power plug connected or is it only for motor dishes? (I use diseqc)
I haven't got such connector on my PSU and the adaptor is for an old molex. I would have to get an adaptor from SATA type connector.
After installing the newest driver for Windoes 8.1 the Device Manager shows only one device "TBS6983 Dual DVBS/S2 BDA Tuners". Is that alright?
willyp
Postby steven » Fri Jul 24, 2015 6:06 pm
Hi willyp
Yea, it is safe.
And about the power plug when you have not connect motor do not need this.
And the device manager message is ok.enjoy your TBS6983 now. :)
