TBS6618 DVB-C issue
TBS6618 DVB-C issue
Postby De7ilx » Wed Jul 15, 2015 10:15 am
I just recently bought "TBS6618 DVB-C TV Tuner CI PCIe Card" and now facing this problem of not getting it to work properly.
I have tried several programs but I do not simply know how to configure the programs to see the TV.
What would be the best program to use with this PCIe card and how to configure it propertly?
I am using CONAX module.
This is the information from my TV service provider website:
Modulation: QAM 256
Channel width: 8 MHz
Symbol speed: 6,875 Msym/s
Starting frequency: 266000 or 266 MHz
Ending frequency: 546000 or 546 MHz
I have Windows 7 64 bit.
I do not wish to use Windows Media Center because soon Windows 10 comes and there will be no Media Center anyways.
Any help is appreciated.
De7ilx
Re: TBS6618 DVB-C issue
Postby steven » Fri Jul 17, 2015 3:18 pm
Hi De7ilx
Can you tell us that which application you are using?
or you can send an email to our support we can help you have a remote setting for you
