TBS-VHID 1.0.0.9 configuration issue & remote control
Postby Bertrand57 » Fri Jun 26, 2015 6:40 pm
Hi everybody,
Here is my problem:
I have a TBS6281 tv card and each time I boot my computer, I have to configure TBS-VHID as follow:
1- Select the device
2- Select the profile and set the options, then apply and save
And I can't launch ProgDVB, the device selected, with the remote control ?
My configuration is
TBS-VHID version 1.0.0.9
TBS6281 driver version 1.0.0.7
ProgDVB 7.05.05a
ProgTV 1.9.0.0
PouchinTV Mod 0.6.2.295
My system is up to date.
How can I fix this ?
TBS6281 tv card
Windows 7 SP1 x64
AMD Radeon HD5850 1 GB
1920 x 1080
Intel Core i7-3770
16 GB Ram
Bertrand57
Re: TBS-VHID 1.0.0.9 configuration issue & remote control
Postby steven » Wed Jul 01, 2015 10:09 am
Hi Bertrand57
Do you mean that you want use TBSVHID to start ProgDVB?
and your setting did not saved your config setting?
Postby Bertrand57 » Wed Jul 01, 2015 4:50 pm
Hi steven,
Thank you for your answer,
Yes, I'd like to use TBS-VHID to start ProgDVB or PouchinTV, with the remote control would be perfect
And yes, the settings I choose are not saved and I have to set the config again each time I boot/reboot my computer
Kind regards
TBS6281 tv card
Windows 7 SP1 x64
1920 x 1080
Intel Core i7-3770
16 GB Ram
Bertrand57
Postby Bertrand57 » Wed Jul 01, 2015 6:06 pm
I would like to add that, in TBSVHID settings, I can't even create or delete a Profile
TBS6281 tv card
Windows 7 SP1 x64
1920 x 1080
Intel Core i7-3770
16 GB Ram
Bertrand57
Postby steven » Mon Jul 20, 2015 5:37 pm
Hi Bertrand57
Sorry that this version have not added this support ,next update we will try to add this support :)
Postby Bertrand57 » Mon Jul 20, 2015 6:03 pm
Hi steven,
Thanks for your reply, sorry to hear that there is no solution to this problem hoping that will be fixed in the next TBSVHID version soon...
Can you tell me if there is an other way using another program, to be able to use the remote control for launching ProgDVB or ProgTV ?
Kind regards
TBS6281 tv card
Windows 7 SP1 x64
1920 x 1080
Intel Core i7-3770
16 GB Ram
Bertrand57
Postby steven » Tue Jul 21, 2015 6:22 pm
Hi Bertrand57
What about WinLIRC
viewtopic.php?f=50&t=7681&hilit=WinLIRC
Maybe you can have a try
kind Regards
Postby Bertrand57 » Tue Jul 21, 2015 6:33 pm
Hi steven,
Great, thank you, I'll give a try on WinLIRC :)
Kind regards
TBS6281 tv card
Windows 7 SP1 x64
1920 x 1080
Intel Core i7-3770
16 GB Ram
Bertrand57
