Proper Installation TBS 5922 in Debian Jesee and Ubuntu
Postby subletra » Tue Jun 23, 2015 9:46 am
Hello. It has been a problem to install the drivers for this device. But I noticed that the instructions are contradictory. If you look at the drivers folder there are 2, 3 types of instructions for installing TBS 5922.
You can look at the README file folder and look at the file in the main directory of the drivers file. Besides indicating that file follow the instructions of a previous model (5921)
In any case, all are deprecated.
Here the correct instructions to install Debian Jessie (and probably Ubuntu):
su -
apt-get update
apt-get install linux-headers-`uname -r`
mkdir /lib/firmware
unzip tbs-linux-drivers_v150525.zip -d tbs
cd tbs
mv dvb-usb-tbsqbox-id5922.fw /lib/firmware/
cd linux-tbs-drivers
./v4l/tbs-x86_64.sh (if kernel 64) ----- ./v4l/tbs-x86.sh (if kernel x86)
make
make install
shutdown -r now
dmesg | grep QBOX
subletra
Re: Proper Installation TBS 5922 in Debian Jesee and Ubuntu
Postby steven » Wed Jun 24, 2015 4:48 pm
Hi subletra
Please have a try
rm -rf /lib/modules/xxx/kernel/driver/media (xxx means your kernel version)
Then reinstall your driver again.
kind Regards
Postby subletra » Wed Jun 24, 2015 9:33 pm
Sorry. I think that is not well understood my English with google translator. The instructions I have given are correct:
su -
    apt-get update
    mkdir /lib/firmware
    cd tbs
    make
    make install
    shutdown -r now
    dmesg | grep QBOX
With these instructions the driver can be installed correctly. Review the instructions that you give in tbs-linux-drivers_v150525.zip because they are incorrect and contradictory.
Thank you.
subletra
