TVHEADEND UPGRADE ON MOI PRO
Postby johnbolt » Fri Jun 12, 2015 3:59 pm
Hello, i have moi pro with 8 tuners and TVHEADEND (3.9+7a2560e-1) and tvheadend is extremely unstable evry day it crashes freezes and so on !!!
i NEED YOU to tell me how i can upgrade ! to the latest verion 4.0.4 ! i know i need to cross compile but how can i do that ! and insatll tvheadend
I saw here there is a compiled one which doesnt mention its version !? anyway how can i install it
Pls reply asap
Best Regards
johnbolt
Re: TVHEADEND UPGRADE ON MOI PRO
Postby steven » Thu Jun 25, 2015 5:39 pm
Here is the 4.0.5 version fo tvheadend please have a try:
https://my.pcloud.com/publink/show?code ... pUS8zFX1aV
Please download it and put to your MOIPro using this command to install
opkg install tvheadend_4.0.5+ffc3ff1-1_armv7.opk
Postby aurimelis » Thu Oct 22, 2015 4:53 am
Hi, i try to upgrade tvheadend but after update it not load any more tvheadend.
Do you know maybe problem ? So what happen i needed to reinstall my moi pro
aurimelis
Postby alfi037 » Wed Oct 28, 2015 5:04 pm
hi
if you update to new tvh version you won't be able to access via web interface (the way you used to set things before ) except using this cmd on telent " tvheadend -C"
why don't you download new image moi pro 1.0.0.8 with latest kernel and Tvh
better than 1.0.0.7 version as far I know
but still you find crashes /hangs the system
I tested 15-20 free to air channels SD ( moi pro+tbs6985 , version 1.0.08 ) but some times still it hangs ! so we have to reboot manually from rear
I don't know who will sort this out !!!
Anyway the latest 1.0.08 image is much better tvh version than the previous ones (less errors)
regards,
alfi
alfi037
Postby pispi » Sun Nov 01, 2015 5:30 am
steven Wrote:Hi
this version work with MOI2921 ??
pispi
Postby dan3o3 » Thu Nov 19, 2015 3:06 am
Any to get a new build? The one from the current Image is freezing nearly every 24h for me.
Thanks,
Dan
dan3o3
Postby tayloirit » Tue Nov 24, 2015 10:16 am
I've also messaged Steven to see if they can compile 4.0.7 for Moi Pro so hopefully they post it up.
tayloirit
Postby hatster » Mon Nov 30, 2015 1:40 am
I have freezing / hanging issue. (v1.0.0.8) I have used tvheanend, and also disabled this and used DVBlast. Both do the same (FTA, not decoding anything). So I have to say I think there is more to this than the tvheadend version. More likely a linux / hardware issue :/
When it hangs, the display also stops cycling the display with the tuner numbers, etc..
hatster
Postby dan3o3 » Tue Dec 01, 2015 10:00 pm
Mhh, for me just the TVHeadend instance is hanging, a "systemctl restart tvheadend" works for me but should not be needed, actually I cannot see the condition for the hanging so my records are all ruined yet.
I am very disapointed about the software support for this special high-price device, also I am not getting the reason why the version numbers are cut off in the MOI binaries. With that you never have a clue which exact version & patchlevel is currently working so you can check errors on tvheadend side.
I badly hope some kind of package management (opkg with an official package tree) will come but I for the moment the device looks very unfinished from a software perspective to me.
Dan
Funny: Just recognized that a new firmware was released today and magically tvheadend has a version number now... :)
dan3o3
Postby developer » Mon Dec 07, 2015 1:30 am
true .. i got this so that i can do live streaming but it keeps on crashing after 1 hr or so ..
Only good for testing for some time.. Doesnt have any instructuins on how to stream ..
developer
Return to MOI Pro
