tbs6982se - modulation 9 is not supported
Postby lev » Thu Jun 11, 2015 4:31 pm
Hi everybody!
I regularly get messages in dmesg from my TBS 6982:
[82162.562858] TurboSight TBS 6982SE Frontend:
[82162.562861]  tbs6982se - modulation 9 is not supported
Modulation 9, according to linux/dvb/frontend.h, is PSK_8. It happens not every day and I haven't discover any pattern.
Also sometimes the card can't tune to transponder or currently displaying channel has a digital noises (TS discontinuity error in libdvbpsi log). There are no problems with signal on other equipment, and after reboot the card works well.
So, the question. Why does this occur?
My system is CentOS 6.5 i386 with kernel 3.2.62. Drivers version v150429. The same problem was with an old drivers (about a year) too.
Also I've TBS 6285 installed in the system.
dmesg:
[    5.083587] tbs6982fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[    5.092205] Disabling lock debugging due to kernel taint
[    5.117505] SAA716x TBS 0000:09:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    5.124998] SAA716x TBS 0000:09:00.0: setting latency timer to 64
[    5.128024] IR NEC protocol handler initialized
[    5.137046] IR RC5(x) protocol handler initialized
[    5.143508] IR RC6 protocol handler initialized
[    5.163475] Registered IR keymap rc-tbs-nec
[    5.165736] IR JVC protocol handler initialized
[    5.167298] IR Sony protocol handler initialized
[    5.168205] IR MCE Keyboard/mouse protocol handler initialized
[    5.169317] lirc_dev: IR Remote Control driver registered, major 250
[    5.169759] IR LIRC bridge handler initialized
[    5.193923] input: saa716x IR (TurboSight TBS 6285) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:0d.0/0000:09:00.0/rc/rc0/input3
[    5.206622] rc0: saa716x IR (TurboSight TBS 6285) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:0d.0/0000:09:00.0/rc/rc0
[    5.218568] input: MCE IR Keyboard/Mouse (saa716x) as /devices/virtual/input/input4
[    5.226341] rc rc0: lirc_dev: driver ir-lirc-codec (saa716x) registered at minor = 0
[    5.234174] DVB: registering new adapter (SAA716x dvb adapter)
[    7.713217] TurboSight TBS 62x1 Frontend:
[    7.713218]  tbs62x1fe - software version is 1.0.0.0
[    8.521524] TurboSight TBS 62x1 Frontend:
[    8.521526]  tbs62x1fe - Successfully Initialized
[    8.531144] TurboSight TBS6285 DVB-T2 card port0 MAC=ff:ff:ff:ff:ff:ff
[    8.537738] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[    8.546684] DVB: registering new adapter (SAA716x dvb adapter)
[   11.042171] TurboSight TBS 62x1 Frontend:
[   11.042172]  tbs62x1fe - software version is 1.0.0.0
[   11.870468] TurboSight TBS 62x1 Frontend:
[   11.870469]  tbs62x1fe - Successfully Initialized
[   11.880088] TurboSight TBS6285 DVB-T2 card port1 MAC=ff:ff:ff:ff:ff:ff
[   11.886680] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[   11.895159] DVB: registering new adapter (SAA716x dvb adapter)
[   14.349126] TurboSight TBS 62x1 Frontend:
[   14.349127]  tbs62x1fe - software version is 1.0.0.0
[   15.157430] TurboSight TBS 62x1 Frontend:
[   15.157431]  tbs62x1fe - Successfully Initialized
[   15.167051] TurboSight TBS6285 DVB-T2 card port2 MAC=ff:ff:ff:ff:ff:ff
[   15.173641] DVB: registering adapter 2 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[   15.182128] DVB: registering new adapter (SAA716x dvb adapter)
[   17.657082] TurboSight TBS 62x1 Frontend:
[   17.657083]  tbs62x1fe - software version is 1.0.0.0
[   18.506376] TurboSight TBS 62x1 Frontend:
[   18.506376]  tbs62x1fe - Successfully Initialized
[   18.516003] TurboSight TBS6285 DVB-T2 card port3 MAC=ff:ff:ff:ff:ff:ff
[   18.522599] DVB: registering adapter 3 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
[   18.531101] SAA716x TBS 0000:0a:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   18.538588] SAA716x TBS 0000:0a:00.0: setting latency timer to 64
[   18.546254] Registered IR keymap rc-tbs-nec
[   18.550540] input: saa716x IR (TurboSight TBS 6982SE) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:0f.0/0000:0a:00.0/rc/rc1/input5
[   18.563414] rc1: saa716x IR (TurboSight TBS 6982SE) as /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:0f.0/0000:0a:00.0/rc/rc1
[   18.575532] input: MCE IR Keyboard/Mouse (saa716x) as /devices/virtual/input/input6
[   18.583301] rc rc1: lirc_dev: driver ir-lirc-codec (saa716x) registered at minor = 1
[   18.591128] DVB: registering new adapter (SAA716x dvb adapter)
[   19.051141] TurboSight TBS 6982SE Frontend Attaching...
[   19.100490] TurboSight TBS6982SE DVB-S2 card port0 MAC=00:22:ab:b1:03:f8
[   19.107255] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6982SE DVBS/S2 frontend)...
[   19.115910] DVB: registering new adapter (SAA716x dvb adapter)
[   19.575972] TurboSight TBS 6982SE Frontend Attaching...
[   19.623696] TurboSight TBS6982SE DVB-S2 card port1 MAC=00:22:ab:b1:03:f9
[   19.630460] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6982SE DVBS/S2 frontend)...
lspci:
09:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 02)
        Subsystem: Device [6285:0001]
        Interrupt: pin A routed to IRQ 17
        Region 0: Memory at f7900000 (64-bit, non-prefetchable) [size=1M]
        Kernel modules: saa716x_tbs-dvb
0a:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
        Subsystem: Device [6982:0002]
        Interrupt: pin A routed to IRQ 19
        Region 0: Memory at f7800000 (64-bit, non-prefetchable) [size=1M]
lev
Re: tbs6982se - modulation 9 is not supported
Postby steven » Thu Aug 20, 2015 11:46 am
Hi lev
Please have a try with our latest linux driver:
http://www.tbsdtv.com/download/document ... 150728.zip
and can you tell us that which soft you are using ?
