(Solved)TBS5881 - no sound with eAC3 (Dolby Digital Plus)
Postby INGBEAN » Wed Jun 03, 2015 5:01 pm
Hello!
I am located in Austria and test the DVB-T2 service called "SimpliTV".
So a cardless module is inserted into TBS5881 (see attachment).
But I don't hear a sound on encrypted channels -> they are sended in eAC3-format (Dolby Digital Plus)!
Question: does this TBS5881-USB-box support eAC3???
I am using DVBViewer (V5.3.2.0) and have installed LAV decoder (V0.65).
By the way: I copied TBS CI API DLL V1.0.1.2 into program folder of DVBViewer to work with CAM.
I made a screenshot (DVB Source shows "Audio State: No data / Connected, PID 2221").
But: I hear AC3-sound on unencrypted channels!
Video is working fine on encrypted AND unencrypted channels.
Please support me to hear eAC3-sounds too!
INGBEAN
INGBEAN
Re: TBS5881 - no sound with eAC3 (Dolby Digital Plus)
Postby steven » Tue Jul 14, 2015 11:10 am
Hi INGBEAN
Thanks for this feedback we already on debug with DVBView,and please check your email
we send some information .
Postby INGBEAN » Tue Jul 14, 2015 3:39 pm
Hello Steven!
Thanks for your E-Mail, I have already replied there.
INGBEAN
INGBEAN
Re: (Solved)TBS5881 - no sound with eAC3 (Dolby Digital Plus
Postby minhasp » Mon Aug 07, 2017 11:33 am
@INGBEAN: your cam module is CI+
but TBS5881 only CI support, It works?
minhasp
Postby minhasp » Tue Jun 04, 2019 11:07 am
steven Wrote:Hi INGBEAN
I installed cam module and it works fine dvb-t2 encrypted channel
I only able to access cam module by tbs ci tool one time, and able to checking subscriber status .
when I open again enter cam menu, it always show status cam status reading cam,
how Can I checking same function in linux, thanks
minhasp
