Windows 10 Support
Windows 10 Support
Postby warumnix » Fri May 29, 2015 2:10 pm
Hi All,
We have received some inquires about Windows 10 support for TBS tuners, good news is that the current driver already supports Window 10, you can download the latest driver from the download page and have a try. Feedback and suggestions are always welcome.
warumnix
Re: Windows 10 Support
Postby Radeon123 » Wed Jul 15, 2015 1:12 pm
I have had my 6220 TV tuner since Aug 2013, it's worked perfectly on Windows 8/8.1 X64, but currently on Windows 10 (build 10166) the latest driver from 2012 (1.0.1.2) is causing very intermittent BSODS, two in the last week. The card is working great apart from the unstable driver.
The BSOD is blaming the file TBS6220_64.sys
Here is the mini dump file if it will be of any use.
http://www.richardtrahar.webspace.virgi ... 765-01.dmp
Here is the specs the rest of the PC that this card is running on. Apart from the TV card driver causing the BSOD, my system is otherwise rock solid.
i7 4790k @ 4GHz / Noctua NH-D14 / Asus Z97 Deluxe
2x MSI GTX 980 Ti Gaming 6G / Samsung 850 Pro 1TB
Kingston HyperX Genesis Grey 1600mhz 16gb (4x 4GB)
Corsair AX860i 860w PSU / Windows 10 Pro 64bit (10166)
Radeon123
Postby steven » Fri Jul 17, 2015 3:10 pm
Hi Radeon123
Thanks for your feedback,Are you using the same PC with windows 8 and windows 10?
And please write an email send this detail information to our support we will have a check with this.
Postby Radeon123 » Sat Jul 18, 2015 4:30 am
Thanks will contact support.
I have since upgraded Windows 10 to build 10240 x64. Everything is running great, but after around 2 days of 24/7 use I have received another BSOD that again blames the TBS6220_64.sys file.
Apart from the TV card causing the occasional BSOD my system is otherwise rock solid.
I have used the TV card on Windows 8 and 8.1 (same PC) for well over a year and 24/7 use and and it's been 100% perfect, Windows 10 was a upgrade over the top of 8.1 that was done via Windows update.
The only thing that's letting the system down is that TV card driver.
Radeon123
Postby Radeon123 » Thu Jul 30, 2015 5:47 am
Still waiting for support to get back to me as I am still getting BSODS with this driver.
Radeon123
Return to News
