IR Receiver stops recordings
Postby accod » Mon May 25, 2015 4:48 pm
I've got a TBS 5922SE connected to a mac mini running as a slave mythtv backend and a frontend. I was using the 5922SE IR receiver but I've found this causes the dvb adapter to stop working. It varied but every 4-24 hours the adapter would stop recording and I'd get this from szap:
status 00 | signal 95% | snr 0% | ber 67108863 | unc 0 |
status 00 | signal 0% | snr 0% | ber 67108863 | unc 0 |
status 00 | signal 62% | snr 0% | ber 67108863 | unc 0 |
Sometimes this would show in syslog:
May 17 14:10:17 mmini kernel: [100575.582861] dvblb_fake_ioctl interrupted: 2147774278
May 17 14:10:17 mmini kernel: [100575.596565] dvbloopback: Got wrong response (2147774278 != 5)
It occurred on the non loopback adapter as well (but using the open source driver - I didn't test the tbs driver).
I forget the source but, after a lot of searching, I found it mentioned that covering the IR receiver with some tape might help. Since doing this about a week ago the problem has not reoccurred. I'm now using a separate IR receiver and all is working great.
Since I had such a hard time searching and resolving this problem, I wanted to post here in case it helps someone else.
Cheers.
accod
