TBS6905 DVB-S2 Quad Adapters not tuning channels
Postby AshG » Thu Apr 30, 2015 3:35 am
I've recently bought a TBS6905 DVB-S2 Quad Tuner PCIe Card, i've installed/compiled the latest Drivers and everything seems ok on Ubuntu 14.02.
dmesg | grep frontend
[ 6.198221] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[ 6.201146] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[ 7.404476] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[ 7.407641] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
Originally i was using the latest 3.9xxx version of TVhead, all muxes & Services scanned ok and the card worked perfectly with 2 clients accessing it at the same time. At the time of set up i only used 2 feeds to 2 inputs (although i do have a quad LNB, the other 2 lines are used by my sky box). I have now uninstalled TVhead and am now testing this with Myth TV backend, i'm using Kodi(XBMC) as the client.
For both TVHead & MythTV, i have an issue when a client disconnects and then tries to reconnect, using the TVhead web interface, i could see that once a client disconnects, the following scenario would occur - & i'm presuming this happens for mythTV (although i haven't worked out how to view signal strength/SNR on myth yet):
When the 2nd Client tries to reconnect, both SNR's % for both adapters would drop down to 1-20% (previously before the disconnect they were both at 100%), both (kodi) clients would lose the connection, in the webportal of TVhead it would show it trying to connect in turn to each adapter, but failing- presumably because of the low SNR. Connecting again to the backend (this is for Both TVhead & Myth) will be impossible (Kodi gives a channel does not exist message) until a full reboot.
Using just one client that uses just one adapter, everything works ok. although, on occasions i still have to reboot after a prolong period of not being used e.g 24 hrs. I like to think by testing this on both TVHEAD & MYTH proves that this is not a software issue, which leaves either it being faulty card, drivers or some other config???? I'm unsure where to turn next? i'm quite a noob to linux, any assistance would be gratefully received !
Edit: i've also just looked at my Dmesg -is this relevant?
[ 4.980080] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 4.985384] [drm] Initialized drm 1.1.0 20060810
[ 4.994833] mei_me 0000:00:16.0: irq 43 for MSI/MSI-X
[ 4.996021] dvb_core: module verification failed: signature and/or required key missing - tainting kernel
[ 4.997113] ppdev: user-space parallel port driver
[ 4.997536] TBS PCIE 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.997621] TBS PCIE Detected TBS6905 Board Rev 1
[ 4.998577] DVB: registering new adapter (TBS PCIE DVB Adapter)
[ 5.003873] ACPI Warning: 0x0000000000000428-0x000000000000042f SystemIO conflicts with Region \PMIO 1 (20131115/utaddress-251)
[ 5.003879] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 5.003882] ACPI Warning: 0x0000000000000530-0x000000000000053f SystemIO conflicts with Region \GPIO 1 (20131115/utaddress-251)
[ 5.003885] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 5.003887] ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \LED_ 1 (20131115/utaddress-251)
[ 5.003889] ACPI Warning: 0x0000000000000500-0x000000000000052f SystemIO conflicts with Region \GPIO 2 (20131115/utaddress-251)
[ 5.003892] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
kind regards
AshG
Re: TBS6905 DVB-S2 Quad Adapters not tuning channels
Postby AshG » Thu Apr 30, 2015 4:32 pm
After plugging the 2 additional inputs from the quad LNB, it appears to be working ok, at the moment.!!
Would only having 2 inputs have the above effect that I previou posted? One thing I noticed when I was testing the connections and swapping the cables around onto the different inputs, mythTV would still use the same adapter, e.g I would change the cable from input 0 to input 1 and it it would stil use adapter 0- I presume the inputs don't relate to the adapters???
If anybody could also feedback what the errors means in my Dmesg, that would be gratefully recieved...
AshG
