Card identification
Card identification
Postby bpbastos » Mon Apr 27, 2015 9:21 pm
Hello guys,
I received this card as replacement for my 6285 but it is missing the identification in the firmare.
Here is my lspci:
07:00.0 Multimedia controller [0480]: Device [544d:6178]
   Subsystem: Device [6205:0001]
   Interrupt: pin A routed to IRQ 11
   Region 0: Memory at f7900000 (32-bit, non-prefetchable) [size=256K]
   Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit+
   Capabilities: [90] Express (v1) Endpoint, MSI 00
      DevCap:   MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
         ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
      DevCtl:   Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported-
         RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
      DevSta:   CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
      LnkCap:   Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us
         ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
      LnkCtl:   ASPM Disabled; RCB 64 bytes Disabled- CommClk+
      LnkSta:   Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
   Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
Is there any way to correct this by flashing a new firmware?
Thank you
bpbastos
Re: Card identification
Postby crazycat » Tue Apr 28, 2015 1:19 am
what firmware ? you must update TBs linux drivers.
Postby bpbastos » Wed Apr 29, 2015 4:03 am
crazycat Wrote:what firmware ? you must update TBs linux drivers.
Sorry, I think I haven't made myself clear. The card is working ok I just found strange that it doesn't show any description using the lspci command.
With the TBS 6285 it shows "03:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 02)".
This information resides in the card firmware or at the linux kernel?
Sorry for the newbie question.
Thanks!
bpbastos
Postby hovis » Tue May 12, 2015 9:00 pm
The information is part of Linux. I think they update from the list found here:-
http://pciids.sourceforge.net
(the vendor '544d' does not exist in the current list)
hovis
