TBS6905 not tunning to any frequency
Postby goncalomsdias » Thu Apr 16, 2015 4:09 pm
Hi!
I have this card acquired very recently directly from TBS, and Im installing it in Ubuntu 14.04.2 (kernel 3.16).
Everything seems ok in the system, but when I try to tune to some frequency, it doesnt work
lspci -vvv
04:00.0 Multimedia controller: Device 544d:6178
        Subsystem: Device 6905:0001
        Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin A routed to IRQ 22
        Region 0: Memory at df100000 (32-bit, non-prefetchable) [size=256K]
        Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [90] Express (v1) Endpoint, MSI 00
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
        Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Kernel driver in use: TBS PCIE
dmesg:
[   10.068503] TBS PCIE 0000:04:00.0: enabling device (0000 -> 0002)
[   10.068650] TBS PCIE Detected TBS6905 Board Rev 1
[   10.073088] DVB: registering new adapter (TBS PCIE DVB Adapter)
[   10.326096] TurboSight TBS 6908 Frontend Attaching...
[   11.414293] TurboSight TBS6908 DVB-S2 card adapter0 MAC=00:22:ab:69:08:01
[   11.414300] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[   11.414509] DVB: registering new adapter (TBS PCIE DVB Adapter)
[   11.415090] TurboSight TBS 6908 Frontend Attaching...
[   11.417797] TurboSight TBS6908 DVB-S2 card adapter1 MAC=00:22:ab:69:08:02
[   11.417802] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[   11.417907] DVB: registering new adapter (TBS PCIE DVB Adapter)
[   11.577605] TurboSight TBS 6908 Frontend Attaching...
[   12.597336] TurboSight TBS6908 DVB-S2 card adapter2 MAC=00:22:ab:69:08:03
[   12.597343] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
[   12.597566] DVB: registering new adapter (TBS PCIE DVB Adapter)
[   12.598125] TurboSight TBS 6908 Frontend Attaching...
[   12.600912] TurboSight TBS6908 DVB-S2 card adapter3 MAC=00:22:ab:69:08:04
[   12.600916] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6908 DVBS/S2 frontend)...
scan-s2 on astra 19.2E:
Network Name 'ASTRA 1'
dumping lists (7 services)
Cherie 25;Arqiva:11778:vC34M2O35S0:S19.2E:27500:1801:1804;1804:0:0:28531:1:1068:0
Cherie 25;Arqiva:11778:vC34M2O35S0:S19.2E:27500:1801:1804;1804:0:0:28550:1:1068:0
Cherie 25;Arqiva:11778:vC34M2O35S0:S19.2E:27500:1801:1804;1804:0:0:28551:1:1068:0
ZDF HD;ZDFvision:11361:hC23M2O35S1:S19.2E:22000:6110:6120=deu,6121=mis,6123=mul;6122=deu:6130:0:11110:1:1011:0
zdf_neo HD;ZDFvision:11361:hC23M2O35S1:S19.2E:22000:6310:6320=deu,6321=mis,6323=mul;6322=deu:6330:0:11130:1:1011:0
zdf.kultur HD;ZDFvision:11361:hC23M2O35S1:S19.2E:22000:6410:6420=deu,6421=mis,6423=mul;6422=deu:6430:0:11140:1:1011:0
Done.
When I try to tune on those scan-s2 frequencys, I get 100% SNR.
The driver version im using is tbs-linux-drivers_v150411.zip
Does anyone has any idea of what's wrong with this? I have never had this problem before.
goncalomsdias
Re: TBS6905 not tunning to any frequency
Postby smile » Wed May 20, 2015 4:33 pm
please update the driver.We have released the latest driver.
Best regards
smile
Postby marcosab » Fri Jul 03, 2015 10:00 am
Hello found a solution, I also have the same problem and have asked several times to support and have not answered anything. I also tell them that I have the latest version of drivers disponibles.Linux Driver v150525
marcosab
Postby cody » Wed Jul 08, 2015 4:22 pm
@marcosab
please, provide exact way how you're trying to scan. most likely there is some mistake there? are you sure there is signal to the adapter you're trying to use on your scan?
Postby wannabe » Sun Aug 09, 2015 12:44 pm
i have the same issue with this model, we update the driver but nothing, not scan any frequency, some one can help us with info to fix this issue ? thanks
wannabe
Postby steven » Mon Aug 10, 2015 4:38 pm
Hi wannabe
Which application you are using ? and what about your config, you can send your detail information to our support#tbsdtv.com
we will reply you ASAP.
kind Regard
