[ Moderator Control Panel ]
by djcslip » Mon Mar 16, 2015 7:29 pm
When i perform a full scan (dvb viewer / dvb dream) i cannot find any channels on certain freqs
Scanning 12552 V 22000... 98%
No channels found!
Scanning 12610 V 22000... 98%
No channels found!
Why is this?
djcslip
by steven » Fri Mar 20, 2015 11:14 am
Hi djcslip
Which driver version you are using ?Please have a try update to the latest version
and for dvbviewer and dvbdream please input the right LNB config it is important.
Or easy way to use a blindscan tool check whether you can find some transponders.
by djcslip » Sat Mar 21, 2015 1:48 am
Windows 7 64bit, driver 1.0.1.5
Latest DVBviewer
LNB 9750, 10600,11700
Any ideas?
Blindscan doesn't see this frequency 12552.. why?
djcslip
