tuning timeouts while CAM plugged in
Postby grt » Fri Mar 13, 2015 4:32 am
i have a TBS6618 and use it under linux via mythtv. But the issue i have is not related to mythtv because it occurs while scanning the cable to channels and mythtv is completly shut down.
When my CAM has NOT been plugged in i can do a "scan -t 1 /etc/channels.conf" and (after a while) i get the complete channels list (the same list as when i scan the channels via my tv-set).
But when i plug in my CAM (quickline smartcard with SMiT CAM, DVB number 5877) i get tuning timeouts and not even one channel (i also tried it for hours without any effect).
This is the dmesg while loading the TBS driver:
tbs6982fe: module license 'TurboSight Proprietary: http://www.tbsdtv.com' taints kernel.
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
lirc_dev: IR Remote Control driver registered, major 248
Registered IR keymap rc-tbs-nec
input: saa716x IR (TurboSight TBS 6618) as /devices/pci0000:00/0000:00:06.0/0000:03:00.0/rc/rc0/input3
rc0: saa716x IR (TurboSight TBS 6618) as /devices/pci0000:00/0000:00:06.0/0000:03:00.0/rc/rc0
input: MCE IR Keyboard/Mouse (saa716x) as /devices/virtual/input/input4
DVB: registering new adapter (SAA716x dvb adapter)
rc rc0: lirc_dev: driver ir-lirc-codec (saa716x) registered at minor = 0
IR LIRC bridge handler initialized
TurboSight TBS6618 DVB-C card MAC=00:22:ab:b2:01:7c
tbsci: Initializing TBS 6618 CI slot
tbsci: Adapter 0 CI slot initialized
DVB: registering adapter 0 frontend 0 (TurboSight TBS 6618 DVBC frontend)...
That's the output while scanning without CAM:
[root@xxx ~]# scan -t 1 /etc/channels.conf
scanning /etc/channels.conf
initial transponder 530000000 6900000 0 5
>>> tune to: 530000000:INVERSION_AUTO:6900000:FEC_NONE:QAM_256
0x0000 0x1844: pmt_pid 0x0000 (null) -- FM1 (running)
0x0000 0x1847: pmt_pid 0x0000 (null) -- FM1 Melody (running)
0x0000 0x1848: pmt_pid 0x0000 (null) -- toxic.fm (running)
0x0000 0x184d: pmt_pid 0x0000 (null) -- Grischa (running)
0x0000 0x099e: pmt_pid 0x07d0 (null) -- KiKA HD (running)
0x0000 0x09a2: pmt_pid 0x07da (null) -- Disney Channel (running)
0x029c 0x09b7: pmt_pid 0x07d0 (null) -- RCK.TV HD (running, scrambled)
0x029c 0x0f21: pmt_pid 0x07da (null) -- Pink plus (running, scrambled)
0x029c 0x0f23: pmt_pid 0x07e4 (null) -- Pink extra (running, scrambled)
0x029c 0x0f25: pmt_pid 0x07ee (null) -- pinkids (running, scrambled)
0x029c 0x0f27: pmt_pid 0x07f8 (null) -- Pink Music (running, scrambled)
0x029c 0x0f2c: pmt_pid 0x0802 (null) -- Hayat BiH (running, scrambled)
0x029c 0x0f2d: pmt_pid 0x080c (null) -- Hayat Plus (running, scrambled)
0x029c 0x0f2f: pmt_pid 0x0816 (null) -- Hayat Folk (running, scrambled)
0x029c 0x0f99: pmt_pid 0x0820 (null) -- TV21 (running, scrambled)
as one can see i also get encrypted channels.....
When i plug in my CAM, i get the following dmesg:
tbsci: Adapter 0 CI slot enabled
dvb_ca adapter 0: DVB CAM detected and initialised successfully
and then while scanning for channels:
WARNING: filter timeout pid 0x0010
dumping lists (0 services)
Done.
When i unplug my CAM and scan, i'm getting the complete channels list as before.
I also tried booting having CAM plugged in, but this doesn't change anything.
So what i'm doing wrong? Is there a (linux-)setup available to get my CAM working and my encrypted PayTV-channels running on the TBS6618?
any help is appreciated.
Kind regards,
T
Here is some more information:
[root@xxx ~]# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] RS880 Host Bridge
00:01.0 PCI bridge: ASUSTeK Computer Inc. AMD RS780/RS880 PCI to PCI bridge (int gfx)
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780 PCI to PCI bridge (ext gfx port 0)
00:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780 PCI to PCI bridge (PCIE port 2)
00:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 3)
00:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] RS780/RS880 PCI to PCI bridge (PCIE port 5)
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 42)
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 IDE Controller (rev 40)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA) (rev 40)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (rev 40)
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
00:16.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:16.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 5
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS880 [Radeon HD 4250]
01:05.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RS880 HDMI Audio [Radeon HD 4200 Series]
02:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 2108 [Liberator] (rev 05)
03:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
04:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
06:05.0 Ethernet controller: 3Com Corporation 3c905 100BaseTX [Boomerang]
[root@xxx ~]# uname -a
Linux xxx.yyy.local 3.10.63-11.el6.centos.alt.x86_64 #1 SMP Tue Jan 6 10:23:44 CST 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@xxx ~]#
grt
