TBS6285 on Linux and other devices
Postby decibel83 » Tue Mar 03, 2015 11:49 am
Hi.
I installed a TBS6285 on my Debian Linux 7.0 amd64 system, and I compiled and installed your drivers.
All worked, and I see /dev/dvb/adapter[X] devices, it uses the cx88_dvb.
But I also have an Hauppauge WinTV-HVR 1100 DVB-T device with radio, and it is not working after the installation of the TBS6285 and its drivers.
This is the dmesg information when the Hauppauge card works:
[    5.898531] cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.9 loaded
[    5.899201] cx88[0]: subsystem: 0070:9800, board: Hauppauge WinTV-HVR1100 DVB-T/Hybrid (Low Profile) [card=41,autodetected], frontend(s): 1
[    5.899203] cx88[0]: TV tuner type 63, Radio tuner type -1
[    5.931674] cx88/0: cx2388x v4l2 driver version 0.0.9 loaded
[    5.972021] cx2388x alsa driver version 0.0.9 loaded
[    6.022183] snd_hda_intel 0000:00:03.0: irq 44 for MSI/MSI-X
[    6.022196] snd_hda_intel 0000:00:03.0: setting latency timer to 64
[    6.070491] i2c-core: driver [tuner] using legacy suspend method
[    6.070492] i2c-core: driver [tuner] using legacy resume method
[    6.078204] tuner 0-0061: Tuner -1 found with type(s) Radio TV.
[    6.126242] tveeprom 0-0050: Hauppauge model 98559, rev A1A0, serial# 405914
[    6.126244] tveeprom 0-0050: MAC address is 00:0d:fe:06:31:9a
[    6.126245] tveeprom 0-0050: tuner model is Philips FMD1216ME (idx 100, type 63)
[    6.126246] tveeprom 0-0050: TV standards PAL(B/G) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xf4)
[    6.126248] tveeprom 0-0050: audio processor is CX882 (idx 33)
[    6.126249] tveeprom 0-0050: decoder processor is CX882 (idx 25)
[    6.126249] tveeprom 0-0050: has radio
[    6.126250] cx88[0]: hauppauge eeprom: model=98559
[    6.184972] tuner-simple 0-0061: creating new instance
[    6.184974] tuner-simple 0-0061: type set to 63 (Philips FMD1216ME MK3 Hybrid Tuner)
[    6.189697] cx88[0]/2: cx2388x 8802 Driver Manager
[    6.189716] cx88[0]/2: found at 0000:04:00.2, rev: 5, irq: 19, latency: 32, mmio: 0xf4000000
[    6.189781] cx88[0]/0: found at 0000:04:00.0, rev: 5, irq: 19, latency: 32, mmio: 0xf6000000
[    6.190945] cx88[0]/0: registered device video0 [v4l2]
[    6.190979] cx88[0]/0: registered device vbi0
[    6.191012] cx88[0]/0: registered device radio0
[    6.191114] cx88[0]/1: CX88x/0: ALSA support for cx2388x boards
[    6.254392] cx88/2: cx2388x dvb driver version 0.0.9 loaded
[    6.254394] cx88/2: registering cx8802 driver, type: dvb access: shared
[    6.254396] cx88[0]/2: subsystem: 0070:9800, board: Hauppauge WinTV-HVR1100 DVB-T/Hybrid (Low Profile) [card=41]
[    6.254398] cx88[0]/2: cx2388x based DVB/ATSC card
[    6.254399] cx8802_alloc_frontends() allocating 1 frontend(s)
[    6.274623] tuner-simple 0-0061: attaching existing instance
[    6.274624] tuner-simple 0-0061: type set to 63 (Philips FMD1216ME MK3 Hybrid Tuner)
[    6.278433] DVB: registering new adapter (cx88[0])
[    6.278435] DVB: registering adapter 0 frontend 0 (Conexant CX22702 DVB-T)...
I need to use both cards in the same system.
With the TBS6285 card installed and its drivers loaded the Hauppauge card is not loaded, and viceversa.
Could you help me to find out if the problem could be the TBS card?
decibel83
