OpenELEC 5.0.4
OpenELEC 5.0.4
Postby vpeter » Sun Mar 01, 2015 12:37 am
OpenELEC 5.0.8
OpenELEC 5.95.1
https://drive.google.com/folderview?id= ... aring#list
Not tested thoroughly. That's why I'm looking for users who would help supporting images for TBS Matrix.
Without some better approach there will be no official images for this system. Or at least no bug reports.
OpenELEC 5.0.4
https://drive.google.com/folderview?id= ... sp=sharing
No support, no bug reports or features requests.
vpeter
Re: OpenELEC 5.0.4
Postby Cjcr » Sun Mar 01, 2015 8:26 pm
vpeter Wrote:OpenELEC 5.0.4
Everything seems working really well. Thank you for the update! I really appreciate the work you did with the updates for Matrix box. ;)
Cjcr
Re: OpenELEC 5.0.4
Postby MikeDotBe » Mon Mar 02, 2015 10:41 pm
is there somewhere a "what's new" between 5.0.4 and 5.0.0 ???
(haven't check their website yet)
MikeDotBe
Re: OpenELEC 5.0.4
Postby bobopalo » Wed Mar 04, 2015 12:30 am
Hi vpeter, I just installed 5.0.4 image on my matrix v1.3. Installation was success, no errors but after starting of openelec after few seconds approx. 10s system freeze. Same result I observed with Openelec 5.0.0.
I don't have serial cable (serial console) and COM port on my PC. No keyboard, no mouse, no UART communication.
Is there any way how to get log file from Matrix v1.3 without serial console?
Thanks, bobopalo
bobopalo
Re: OpenELEC 5.0.4
Postby bobopalo » Thu Mar 05, 2015 3:20 am
log file from Startup openelec 5.0.4 (from start to freeze)
StartupLog_5.0.4.txt.zip
(2.78 KiB) Downloaded 1225 times
bobopalo
Re: OpenELEC 5.0.4
Postby vpeter » Thu Mar 05, 2015 3:42 am
bobopalo Wrote:... my matrix v1.3 ... approx. 10s system freeze
I tested on v1.2 (don't have v1.3) and it is working. Can you try without HDMI cable connected and without anything on USB?
vpeter
Re: OpenELEC 5.0.4
Postby bobopalo » Thu Mar 05, 2015 5:00 am
attached logs are without any devices in USB ports, no HDMI cable, no Ethernet cable. Zip file contains log file from installation and Startup of Openelec 5.0.4 on HW version 1.3
TBS-Matrix_logfiles.zip
log files
(5.43 KiB) Downloaded 1410 times
bobopalo
Re: OpenELEC 5.0.4
Postby vpeter » Thu Mar 05, 2015 3:38 pm
I don't know what is wrong. Can't help.
Maybe you can add parameter clocksource=jiffies to bootargs parameters uEnv.txt file before installing.
vpeter
Re: OpenELEC 5.0.4
Postby bobopalo » Fri Mar 06, 2015 3:40 am
I added bootargs parameters to end of line in uEnv.txt. It's OK?
mmcargs=setenv bootargs 'boot=/dev/mmcblk0p1 disk=/dev/mmcblk0p2 progress debugging console=ttymxc0,115200 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 dmfc=3 consoleblank=0 clocksource=jiffies'
TBS-Matrix-log.zip
log files with added parameter clocksource=jiffies
(10.99 KiB) Downloaded 1212 times
bobopalo
Re: OpenELEC 5.0.4
Postby vpeter » Fri Mar 06, 2015 3:51 pm
bobopalo, I don't have any clue why your system doesn't work. Sorry.
vpeter
Return to Announcements
