ethernet speed - 100 or 1000?
Postby mgrozdanov » Fri Feb 27, 2015 7:36 pm
Hi, I have MOI Pro. When connect ethernet port to L3 switch(zyxel XGS4728F), port of switch indicate, that speed of interface is 100 Mbit/s. The same is situation with another switch(edge-core 4810-12m), and same with simple 8port gigabit switch.
I know that the port of MOI Pro is 100/1000 and I need speeds over 100Mb/s.
nothing in config of MOI is changed.
What could be the problem?
mgrozdanov
Re: ethernet speed - 100 or 1000?
Postby steven » Wed Mar 11, 2015 6:06 pm
Hi mgrozdanov
What about the net cable you connect to MOIPro,maybe you can have a try change the cable.
Return to MOI Pro
