Problem with TBS QBOX S2 (USB)
Postby connectoid » Thu Feb 26, 2015 8:43 am
Hello!
I have a problem witn locking my DVB card TBS QBOX S2 on the sattelite (i'm using it for Internet connection).
Since my sattelite provider moved on 8PSK modulation technology, i have a problems with "locking".
The connection is long or not occur at all. The signal from sattelite is good for locking, but it is not locking or locking after a long time.
Whether there is a newer driver than the one that is on the official site?
Had anyone similar problems?
connectoid
Re: Problem with TBS QBOX S2 (USB)
Postby smile » Fri Feb 27, 2015 2:56 pm
The QBOX S2 is an older product.We have some more stable and adapt to more modulation mode products.like TBS6925(USB2.0),TBS6983(PCIe,2tuner),TBS6908(pcie,4 tuner),etc, you can see this :http://www.tbsdtv.com/products/ it is these products introduction.
Best Wish
smile
