Signal strength/Quality
Postby Psilos » Mon Feb 23, 2015 3:27 pm
This is actually for the TBS 5281.
The device reports Strength:0 Quality:90 Locked:1 on every channel, whether there is a broadcast on the channel or not.
Using driver 1.0.0.1.
Psilos
Re: Signal strength/Quality
Postby smile » Fri Feb 27, 2015 5:25 pm
Hi psilos
What is the player soft you used? let me test it .
smile
Postby Psilos » Sun Mar 01, 2015 2:50 am
Psilos
Postby Psilos » Mon Apr 06, 2015 7:33 am
Any update on this?
Psilos
Postby Psilos » Thu May 21, 2015 12:18 pm
Can someone at TBS answer what the proper calls to the driver are to get ths signal strength and quality?
Psilos
Postby danielpugh » Fri Jun 12, 2015 4:38 pm
I have just received the same usb card. It installed ok. I can find channels in mce but on viewing any channel it fails to show anything because of weak signal.
it works in dvbviewer.
drivers for this model (unlike all the pcie cards) have not been updated since windows 7. PCIE models seem to have had an update for windows 8 and some mention a signal strength issue.
support guidance was to use dvbviewer as mce is difficult. Very strange as I have used many cards with MCE without any problems (multiple black gold and WinTV nova).
it would seem support for this card and mce is limited.
danielpugh
Postby smile » Thu Jun 25, 2015 4:50 pm
Hi all,
I am so sorry for missing the topic.@Psilos: sorry,can you give me some screenshot about this problem.
@danielpugh : this card can support MCE .i will test it again.
Best Regards
smile
Postby Psilos » Mon Oct 26, 2015 3:40 pm
This is a screenshot of the scan window of the oem dvbdream 2.6 p3 from the tbs download page. I scanned a frequency with no signal. Yet level and quality of 90% are reported and also that the signal is locked (lower left). This happens for every frequency whether it has signal or not.
From dvbdream. Scan of a frequency wwith no signal.
Psilos
Postby smile » Wed Oct 28, 2015 11:05 am
Hi Psilos ,
We are sorry for that,this is a bug.We will fix it .if you never mind,please use the current version driver for a while.
Best Regards
smile
Postby Psilos » Sun Jun 05, 2016 1:48 am
Hi, is there a plan to update the driver? It's been over 7 months since it was promised.
Thanks.
Psilos
