HELP! TBS 5922SE won't Lock under Win7 64bit
Postby auxius » Fri Feb 20, 2015 7:28 pm
I can't lock a signal on every satellite under Win7 64bit the software i used are DVB Dream,EBS Lite, DVBViewer and DVBProg at first i thought it was my 10 n 1 diseqc switch is the problem so i tried to swap it to 4 in 1 diseqc but still no lock. But when i tried to run it on Windows XP mode on my Win7 64bit, it works well and i have signal locked so my guess is the driver issue?
I just bought this a week ago and just arrived yesterday.
Driver v1.0.0.3
My specs(Laptop):
Win7 64Bit, 8GB ram, Nvidia 840 VC.
auxius
Re: HELP! TBS 5922SE won't Lock under Win7 64bit
Postby auxius » Sat Feb 21, 2015 4:52 am
*update
1 time it suddently lock a signal on DVB dream but right after i close the software and re run it it couldn't lock up again. :(
auxius
Postby auxius » Mon Feb 23, 2015 10:29 am
*update
I also tried it on Windows 7 32bit with 1.0.0.3 driver at first it works flawless but after installing DVBviewer somethings wrong after a restart im not sure if that is the cause of the problem. My keyboard appears to be pressing on it's own it's like hitting TAB button and ENTER but when i try to unplug the USB it back to normal. At first clean install with driver, dvb dream and EBS all was ok. Hope someone will fix this it's a driver issue for sure.
Cheers
auxius
