Ubuntu 14.04 problem TBS 6982
Postby man2 » Thu Feb 12, 2015 12:24 am
i install Ubuntu server 14.04 and i cannot to setup this card to work ,any time working any time not working , and on frequancy from Simbolrare 3000 cannot scan 8psk Vertikal /Horizontal on 39e satelite .
please TBS support to write here detail how to configure this card to working real .i tested all version instalation not working .
i use new driver 15 ,old 14 ,13 only 14 any time working any time not working , or please which OS Linux need to install to working stable ,i need for Tvheadend .
/root/tbs/linux-driver-tbs/./v41/tbs-x86_64.sh
Linux ubuntu 3.13.0-45-generic #74-Ubuntu SMP Tue Jan 13 19:36:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
root@ubuntu:~# lsdvb
Version: 0.0.4
Copyright (C) Manu Abraham
SAA716x TBS (1131:7160 6982:2) on PCI Domain:0 Bus:0 Device:0 Function:0
DEVICE:0 ADAPTER:0 FRONTEND:0 (TurboSight TBS 6982SE DVBS/S2 frontend)
FE_QPSK Fmin=950MHz Fmax=2150MHz
DEVICE:0 ADAPTER:1 FRONTEND:0 (TurboSight TBS 6982SE DVBS/S2 frontend)
one time working on time not working
log from install.rar
(84 Bytes) Downloaded 497 times
man2
Re: Ubuntu 14.04 problem TBS 6982
Postby Souldream » Wed Apr 08, 2015 11:23 pm
I installed it over a 14.4 Ubuntu x64.
So far i installed Enigma2 , all compiled ok , driver, libs , enigma2.
Problem that i can not figure it out yet, is Scanning is ok ... and no live TV :twisted:
I have no error , nothing, dmesg is ok , i need to dig.
I am sad really that i start to see the support of TBS is VERY WEAK for a manufacturer, usually if you have a forum this is for getting a better Knowledge FAQ and reply more faster to fix any problem ( most of time ) they are usual...
But here when i read the forum and all the post left with no answer .... i was planning to buy Moi Pro device to make my own LAN ... but i think i must really find another hardware ...
Sad but if i have the same problem with a called "PRO" card sold more then 200 euros, i could expect a better support ... from the main company and not really from some users ( if either their help is usefull as well ).
My 2 cents !
Souldream
