TBS6285 Mythbuntu DVB-T tuning fail
Postby tcinnes » Tue Feb 03, 2015 4:17 pm
I had the TBS6285 working perfectly for over a year on MYTHBUNTU 12 ... but recently upgraded to MYTHBUNTU 14 and now cannot get the card to work - here are some symptoms:
Have installed driver in with following output
root@mythtv2:~/tbs/scan-s2# dmesg | grep frontend
[ 15.422765] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x1 DVBC frontend)...
[ 15.614729] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x1 DVBC frontend)...
[ 15.806637] DVB: registering adapter 2 frontend 0 (TurboSight TBS 62x1 DVBC frontend)...
[ 15.994597] DVB: registering adapter 3 frontend 0 (TurboSight TBS 62x1 DVBC frontend)...
I when trying to tune to Australian DVB-T in MythTV I get "error parsing parameters"
so I resorted to using 'scan' and 'channels.conf' but I still get errors as follows:
root@mythtv2:~/tbs/scan-s2# scan /usr/share/dvb/dvb-t/au-Canberra-Black-Mt > ~/.tzap/channels.conf
scanning /usr/share/dvb/dvb-t/au-Canberra-Black-Mt
initial transponder 205500000 1 3 9 3 1 1 0
initial transponder 226500000 1 3 9 3 1 1 0
initial transponder 219500000 1 3 9 3 1 1 0
initial transponder 177500000 1 3 9 3 1 1 0
initial transponder 543500000 1 2 9 3 1 2 0
>>> tune to: 205500000:INVERSION_AUTO:BANDWIDTH_7_MHZ:FEC_3_4:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_16:HIERARCHY_NONE
__tune_to_transponder:1910: ERROR: Setting frontend parameters failed: 22 Invalid argument
>>> tune to: 226500000:INVERSION_AUTO:BANDWIDTH_7_MHZ:FEC_3_4:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_16:HIERARCHY_NONE
>>> tune to: 219500000:INVERSION_AUTO:BANDWIDTH_7_MHZ:FEC_3_4:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_16:HIERARCHY_NONE
>>> tune to: 177500000:INVERSION_AUTO:BANDWIDTH_7_MHZ:FEC_3_4:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_16:HIERARCHY_NONE
>>> tune to: 543500000:INVERSION_AUTO:BANDWIDTH_7_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_8:HIERARCHY_NONE
ERROR: initial tuning failed
dumping lists (0 services)
Done.
I suspect it is driver related ... is there a DVB-T driver for TBS6285?
any clues???
tcinnes
Re: TBS6285 Mythbuntu DVB-T tuning fail
Postby smile » Sat Feb 28, 2015 11:25 am
Hi tcinnes
you installed the wrong driver.
"root@mythtv2:~/tbs/scan-s2# dmesg | grep frontend
[ 15.994597] DVB: registering adapter 3 frontend 0 (TurboSight TBS 62x1 DVBC frontend)..."
This is DVBC driver ,not DVBT.
please reinstall the driver.fellow the steps :
I.1 extract linux-tbs-drivers.tar.bz2 archive:
# tar xjvf linux-tbs-drivers.tar.bz2
I.2 go to driver package directory:
# cd linux-tbs-drivers
I.3 depending on your kernel version and if the kernel is x86 or
x86_64 (check output of 'uname -a') do:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
# ./v4l/tbs-x86_64.sh
I.4 build and install the driver:
# make && make install
I.5 reboot in order to load the newly installed driver:
# shutdown -r now
pls try it again
smile
