TBS6983
TBS6983
Postby dellboy » Tue Jan 27, 2015 2:44 am
Just installed a TBS6983 on a Windows 7 x64 PC. I have been able to do a blindscan and found all the channels I expected. Some channels are fine using DVB Dream, however some channels have a problem with picture and sound breaking up. I think it is a codec issue or a video rendering issue. Please could someone let me know the best codecs and rendering mode to use with this card and using DVB Dream?
dellboy
Re: TBS6983
Postby crazycat » Tue Jan 27, 2015 3:57 am
or signal issue :)
Re: TBS6983
Postby diabloss » Tue Jan 27, 2015 4:14 pm
@crazycat
Any chances to see and use some new drivers from you for 6908 / 6904 cards?
Excellent work btw ... thank you very much.
diabloss
Re: TBS6983
Postby satesco » Tue Jan 27, 2015 7:13 pm
If you do not have problems with the signal, as @CrazyCat thinks,then try codecs I use on DVB Dream. Everything works perfectly with Lav codec even on UHD channel.
Run the same system, Windows 7x64.Maybe help.
satesco
Re: TBS6983
Postby crazycat » Wed Jan 28, 2015 5:19 am
hmm, what my driver ? :) i not write any drivers.
diabloss Wrote:@crazycat
Re: TBS6983
Postby dellboy » Fri Jan 30, 2015 3:37 am
Signal is fine. Some channels are fine, but some are breaking up - the difference is that the ones that are breaking up are on ACM feed. Do the ACM channels need different decoding or anything like that? I was thinking of getting a dedicated graphics card to see if it helps but a good graphics card will be quite expensive!! So if you know of any cheaper way of doing it then please let me know. Thanks!!
dellboy
Re: TBS6983
Postby diabloss » Fri Jan 30, 2015 6:48 pm
crazycat Wrote:hmm, what my driver ? :) i not write any drivers.
Thought liplianin drivers modifications / aditions are belonging to you... my mistake.
diabloss
Re: TBS6983
Postby crazycat » Sat Jan 31, 2015 8:22 am
dellboy Wrote:Signal is fine. Some channels are fine, but some are breaking up - the difference is that the ones that are breaking up are on ACM feed. Do the ACM channels need different decoding or anything like that?
ACM used for data channels.
TV feeds usual CCM, transport stream.
So you need CrazyScan or EBS Pro for "deep signal analysis". DVBDream suitable only for view TV and reported signal level/quality not fine :)
