No sound with HDMI
No sound with HDMI
Postby Abraxus » Sat Jan 24, 2015 3:53 am
Hi everyone,
I just receive my new TBS2910 but the sound doesn't work.
I check in the audio setting and there is no "HDMI" in output. I don't know what to do. I try to burn a new OS but i doesn't work to i got an error Bootstrap with Mfgtool.
Other thing weird : i try to check the version of my tbs but there is no v1.3 or v2.1 on the PCB ... nothing is written.
Any help ?
Thanks you very much
Abraxus
Re: No sound with HDMI
Postby Abraxus » Sat Jan 24, 2015 7:12 am
Ok i found the problem. I didn't see the config menu at the beginning and i can select the HDMI output.
But now i have a second problem. I install several addon. After a reboot, the TBS stopped to work ! My TV is black and blinking. But i can connect in SSH to it. So the TBS is booting up, but screen is black and blinking.
I try to burn a new OS but Mfgtool doesnt work. There is 2 cases :
-> It stuck on Loading U-Boot
-> Mfgtool stopped with a bootstrap fail error. Here is the pastebin of the logs http://pastebin.com/BHHMmpXm. There is a writing error in the lines.
And i don't know to see what is the version of my TBS because there is nothing printed on the pcb...
Anyone have an idea ? I already change my TBS on DTV :/
Abraxus
Return to Install and setup
