Oscam fail
Oscam fail
Postby guaresi » Wed Jan 14, 2015 3:52 pm
Hello,y have a some problems with the oscam from my Moi Pro.The oscam work with Tvheadend for 1 hour sometimes only 30 minutes and then Oscam fail to decript channel but if y restart Oscam everything are normal for another hour sometimes maybe last.The oscam work with a C line from Multics y also put N line from Multics y try with lines from another oscam server and its make the same thing.Y forget to mention i using satelite channels.It is posibile to compile another Oscam? Because this Linux distribution do not work with comun comands,even reboot not work.Thank you
guaresi
Re: Oscam fail
Postby diabloss » Fri Jan 16, 2015 3:40 am
can you try with this one which is attached here
oscam.zip
(613.67 KiB) Downloaded 533 times
diabloss
Return to MOI Pro
