TBS6285 complete system freeze
Postby eponymous » Tue Jan 06, 2015 6:25 pm
I've got a TBS6285 with the 141225 drivers installed. I also have a Hauppauge NOVA-HD-S2 (PCI) which works flawlessly.
I'm using TVHeadend 3.4.27 and Gentoo with Kernel 3.16.5 and the motherboard is an ASUS P9D-E4L.
I don't have access to the machine at the moment so can't get the output of lspci -vvnn just yet.
It seems that everything works fine and I can tune and watch channels on all four tuners. However, after around a day or so of running, my system will freeze completely to the point where I have to press the reset switch.
There are no messages in dmesg.
I'm running the TBS module with the following parameters:
int_type=1
enable_ir=0
I've also tried with int_type=0 and it still doesn't fix the issue. I've also tested the 141217 drivers which has the same problem.
Output of dmesg at system startup:
Jan  6 08:09:58 main kernel: [   11.095039] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   11.095039]  tbs62x1fe - software version is 1.0.0.0
Jan  6 08:09:58 main kernel: [   11.935536] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   11.935536]  tbs62x1fe - Successfully Initialized
Jan  6 08:09:58 main kernel: [   11.936317] TurboSight TBS6285 DVB-T2 card port0 MAC=ff:ff:ff:ff:ff:ff
Jan  6 08:09:58 main kernel: [   11.936319] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
Jan  6 08:09:58 main kernel: [   11.936445] DVB: registering new adapter (SAA716x dvb adapter)
Jan  6 08:09:58 main kernel: [   14.386815] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   14.386815]  tbs62x1fe - software version is 1.0.0.0
Jan  6 08:09:58 main kernel: [   15.208314] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   15.208314]  tbs62x1fe - Successfully Initialized
Jan  6 08:09:58 main kernel: [   15.209095] TurboSight TBS6285 DVB-T2 card port1 MAC=ff:ff:ff:ff:ff:ff
Jan  6 08:09:58 main kernel: [   15.209096] DVB: registering adapter 2 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
Jan  6 08:09:58 main kernel: [   15.209224] DVB: registering new adapter (SAA716x dvb adapter)
Jan  6 08:09:58 main kernel: [   17.741589] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   17.741589]  tbs62x1fe - software version is 1.0.0.0
Jan  6 08:09:58 main kernel: [   18.541085] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   18.541085]  tbs62x1fe - Successfully Initialized
Jan  6 08:09:58 main kernel: [   18.541866] TurboSight TBS6285 DVB-T2 card port2 MAC=ff:ff:ff:ff:ff:ff
Jan  6 08:09:58 main kernel: [   18.541867] DVB: registering adapter 3 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
Jan  6 08:09:58 main kernel: [   18.541995] DVB: registering new adapter (SAA716x dvb adapter)
Jan  6 08:09:58 main kernel: [   20.992367] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   20.992367]  tbs62x1fe - software version is 1.0.0.0
Jan  6 08:09:58 main kernel: [   21.812861] TurboSight TBS 62x1 Frontend:
Jan  6 08:09:58 main kernel: [   21.812861]  tbs62x1fe - Successfully Initialized
Jan  6 08:09:58 main kernel: [   21.813642] TurboSight TBS6285 DVB-T2 card port3 MAC=ff:ff:ff:ff:ff:ff
Jan  6 08:09:58 main kernel: [   21.813643] DVB: registering adapter 4 frontend 0 (TurboSight TBS 62x1 DVBT/T2 frontend)...
This is getting very frustrating now as I've paid an awful lot of money for this card.
eponymous
Re: TBS6285 complete system freeze
Postby steven » Thu Jan 22, 2015 5:39 pm
Hi eponymous
Please send your detail information to our linux support euro_support#tbsdtv.com
we will reply you as soon as possible.
