Pre-Purchase MOI Pro + Questions
Postby qz3fwd » Mon Dec 08, 2014 5:58 am
I have a couple questions before purchasing the MOI Pro+.
1. What is the purpose of the HDMI output on the back of the mainboard? Will this device run XBMC?
2. If HDMI/XBMC is functional, does the device hardware decode MPEG2/H.264 and does it have enough CPU/GPU power to record and decode concurrently?
3. Does the motherboard have a functional SATA plug such that one could fit a small 2.5 inch HDD inside for recording storage?
4. Is this TBS product supported by TSReader Pro? Maybe I should just ask Rod the TSR developer.
Thank you.
qz3fwd
Re: Pre-Purchase MOI Pro + Questions
Postby diabloss » Wed Dec 10, 2014 9:04 pm
For the first 3 questions the answer is Yes to all 3 of them.
For the 4th question i don't know
diabloss
Return to MOI Pro
