TBS 5881 - Scan fails with "Scan no Data. Failed"
Postby aizukanne » Mon Dec 01, 2014 4:49 pm
I am using TBS 5881 with the latest drivers on Ubuntu 14.04-1. Drivers installed with no issues but scan fails with the "No Data". I tried scanning with w_scan and TVHeadend and the result was the same. System detects the card, is able to see the carrier but unable to scan channels after that.
Output from w_scan
sadmin@Smartflix-Daniel:~$ sudo w_scan -ft -c NG
w_scan version 20130331 (compiled for DVB API 5.10)
using settings for NIGERIA
Country identifier NG not defined. Using defaults.
scan type TERRESTRIAL, channellist 4
output format vdr-2.0
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
/dev/dvb/adapter0/frontend0 -> TERRESTRIAL "TurboSight TBS 5881 DVBT/T2 frontend": good :-)
Using TERRESTRIAL frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
frontend 'TurboSight TBS 5881 DVBT/T2 frontend' supports
INVERSION_AUTO
QAM_AUTO
TRANSMISSION_MODE_AUTO
GUARD_INTERVAL_AUTO
HIERARCHY_AUTO
FEC_AUTO
FREQ (42.00MHz ... 1002.00MHz)
Scanning 7MHz frequencies...
177500: (time: 00:00)
184500: (time: 00:05)
191500: (time: 00:09)
198500: (time: 00:14)
205500: (time: 00:19)
212500: (time: 00:24)
219500: (time: 00:28)
226500: (time: 00:33)
Scanning 8MHz frequencies...
474000: (time: 00:38)
482000: (time: 00:43) (time: 00:44) signal ok:
QAM_AUTO f = 482000 kHz I999B8C999D999T999G999Y999
Info: no data from NIT(actual)
490000: (time: 00:59) (time: 01:01) signal ok:
QAM_AUTO f = 490000 kHz I999B8C999D999T999G999Y999
498000: (time: 01:15) (time: 01:17) signal ok:
QAM_AUTO f = 498000 kHz I999B8C999D999T999G999Y999
506000: (time: 01:31)
514000: (time: 01:35)
522000: (time: 01:40)
530000: (time: 01:45)
538000: (time: 01:49)
546000: (time: 01:54)
554000: (time: 01:59)
562000: (time: 02:04)
570000: (time: 02:08)
578000: (time: 02:13)
586000: (time: 02:18) (time: 02:19) signal ok:
QAM_AUTO f = 586000 kHz I999B8C999D999T999G999Y999
594000: (time: 02:33) (time: 02:34) signal ok:
QAM_AUTO f = 594000 kHz I999B8C999D999T999G999Y999
602000: (time: 02:49)
610000: (time: 02:53)
618000: (time: 02:58)
626000: (time: 03:03) (time: 03:04) signal ok:
QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999
634000: (time: 03:18)
642000: (time: 03:23)
650000: (time: 03:28)
658000: (time: 03:32)
666000: (time: 03:37)
674000: (time: 03:42)
682000: (time: 03:47)
690000: (time: 03:51)
698000: (time: 03:56)
706000: (time: 04:01)
714000: (time: 04:06)
722000: (time: 04:10)
730000: (time: 04:15) (time: 04:16) signal ok:
QAM_AUTO f = 730000 kHz I999B8C999D999T999G999Y999
738000: (time: 04:30)
746000: (time: 04:35)
754000: (time: 04:40)
762000: (time: 04:45)
770000: (time: 04:49)
778000: (time: 04:54)
786000: (time: 04:59)
794000: (time: 05:04)
802000: (time: 05:08)
810000: (time: 05:13)
818000: (time: 05:18)
826000: (time: 05:23)
834000: (time: 05:27)
842000: (time: 05:32)
850000: (time: 05:37)
858000: (time: 05:41)
tune to: QAM_AUTO f = 482000 kHz I999B8C999D999T999G999Y999
(time: 05:46) Info: no data from PAT
Info: no data from SDT(actual)
tune to: QAM_AUTO f = 490000 kHz I999B8C999D999T999G999Y999
(time: 06:02) Info: no data from PAT
tune to: QAM_AUTO f = 498000 kHz I999B8C999D999T999G999Y999
(time: 06:18) Info: no data from PAT
tune to: QAM_AUTO f = 586000 kHz I999B8C999D999T999G999Y999
(time: 06:34) Info: no data from PAT
tune to: QAM_AUTO f = 594000 kHz I999B8C999D999T999G999Y999
(time: 06:49) Info: no data from PAT
tune to: QAM_AUTO f = 626000 kHz I999B8C999D999T999G999Y999
(time: 07:04) Info: no data from PAT
tune to: QAM_AUTO f = 730000 kHz I999B8C999D999T999G999Y999
(time: 07:18) Info: no data from PAT
dumping lists (0 services)
Done.
Here are the log lines from TVHeadend
"2014-11-30 14:31:47.000 mpegts: 594MHz in Star Times - tuning on TurboSight TBS 5881 DVBT/T2 frontend : DVB-T #0
2014-11-30 14:31:47.000 subscription: 0011: "scan" subscribing to mux, weight: 1, adapter: "TurboSight TBS 5881 DVBT/T2 frontend : DVB-T #0", network: "Star Times", mux: "594MHz", hostname: "", username: "", client: ""
2014-11-30 14:31:52.143 mpegts: 594MHz in Star Times - scan no data, failed
lsusb Output
root@Smartflix-Daniel:/home/sadmin# lsusb
Bus 002 Device 003: ID 0461:0010 Primax Electronics, Ltd HP Keyboard
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 13d3:3273 IMC Networks 802.11 n/g/b Wireless LAN USB Mini-Card
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 734c:5881 TBS Technologies China
Bus 003 Device 002: ID 0bc2:5071 Seagate RSS LLC
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
uname -a Output
root@Smartflix-Daniel:/home/sadmin# uname -a
Linux Smartflix-Daniel 3.13.0-40-generic #69-Ubuntu SMP Thu Nov 13 17:53:56 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
This is the status screen when TVHeadend runs a scan.
aizukanne
Re: TBS 5881 - Scan fails with "Scan no Data. Failed"
Postby dede » Fri Apr 06, 2018 12:39 pm
Still same thing, scan fails with NO PAT DATA with opensource driver. And 170330 doesnt work with newer kernels. Can someone from TBS comment on this already? Im writing about this for a year already. Opensource driver is broken, proprietary driver isnt updated for a year. So what to do? Throw away and never buy TBS again?
dede
Postby steven » Sun Apr 08, 2018 3:08 pm
Is driver 170330 works with the older kernel ?and please send email to support#tbsdtv.com to get fast reply
