good Tip
good Tip
Postby johnnysamu » Fri Nov 21, 2014 3:20 am
To set the correct time in the operating system does the following:
sign in, SSH (putty) root, root
su
ntpd -q -p 193.11.166.2 # (ntp server)
date 18:24
___________________________________________________
login as: root
root@192.168.0.86's password:
[root@moipro ~]# su
[root@moipro ~]# ntpd -q -p 193.11.166.2
[root@moipro ~]# date 20:15
Thu Nov 20 20:15:00 UTC 2014
[root@moipro ~]#
johnnysamu
good Tip
Postby johnnysamu » Tue Nov 25, 2014 4:49 am
If you get the error "" bad address "messages" for example with wget then
You need to have the nameservers in /etc/resolv.conf right.
example nameserver 8.8.8.8 #or 192.168.0.1
[root@moipro /]# cd ..
[root@moipro /]# su
[root@moipro /]# nano /etc/resolv.conf
# Generated by Connection Manager
nameserver 192.168.0.1
nameserver ::1
johnnysamu
Re: good Tip
Postby dulcet » Thu Nov 27, 2014 7:53 pm
thanks johnnysamu
i followed your both trick but still nothing change in timezone and resolve hostname
when i change it resolv.conf internet working and after reboot i check nameserver going to default mode
regard's
dulcet
dulcet
Re: good Tip
Postby vpeter » Thu Nov 27, 2014 8:47 pm
For DNS server try to add it in file /etc/network under DNS_SERVER.
vpeter
Re: good Tip
Postby johnnysamu » Sun Dec 07, 2014 6:52 pm
vpeter Wrote:For DNS server try to add it in file /etc/network under DNS_SERVER.
login:
[root@moipro ~]# cd /etc
[root@moipro /etc]# nano network
In the file, change to your time servers
# set to "" to disable NTP
TIMESERVERS="0.se.pool.ntp.org 1.se.pool.ntp.org 2.se.pool.ntp.org 3.se.pool.ntp.org"
ctrl and x
johnnysamu
Re: good Tip
Postby johnnysamu » Sun Dec 14, 2014 4:32 am
Write in your browser http://192.168.0.86/utilities.html Your IP address too moi pro of course. ;)
johnnysamu
Re: good Tip
Postby johnnysamu » Sat Jan 03, 2015 1:12 am
ln -sf /usr/share/zoneinfo/Europe/Stockholm /etc/localtime
and / or
nano /etc/sysconfig
TZ="Europe/Stockholm"
Reboot
ln -sf /usr/share/zoneinfo/Europe/Amsterdam /etc/localtime
johnnysamu
Re: How too backup tvheadend
Postby johnnysamu » Sat Mar 14, 2015 6:01 pm
To reinstall the MIO Pro with your copy of tvheadend
I recommend typing cd "/(null)/.hts/" . Or download Total Commander http://www.ghisler.com/ and set the computer B to " /(null)/.hts/ " . after that you can easily , pull over a copy of tvheadend to your computer.
When you need to use the copy you can, for example, do the following:
1.Start up the formatted MOI pro . Configure Network and TVheadend via moi pros web page .
2. restart Total Commander and set the B side at the address \\ your ip to moi pro \ root \ (null) \ . Hts \ *. *
3. pull your copy to window
johnnysamu
Re: password
Postby johnnysamu » Sun Mar 15, 2015 1:02 am
To change the password.
go in via ssh (such as PuTTY) and login type " passwd " and follow the instructions .
johnnysamu
Re: good Tip
Postby johnnysamu » Sat Feb 25, 2017 3:13 am
ln -snf /usr/share/zoneinfo/Europe/Stockholm /etc/localtime
johnnysamu
Return to MOI Pro
