tbs 6981 new installation on ubuntu 14.04 64 lts
Postby luke81 » Thu Nov 20, 2014 5:12 am
I'm trying to setup my dual card tbs 6981 on my system (ubuntu 14.04.1):
After I've made a clean install of the SO I have followed the readme instructions and this is what I've made:
salotto@salotto:~$ sudo su
[sudo] password for salotto:
root@salotto:/home/salotto# cd /
root@salotto:/# ls
bin    dev   initrd.img  lost+found  opt   run   sys  var
boot   etc   lib         media       proc  sbin  tmp  vmlinuz
cdrom  home  lib64       mnt         root  srv   usr
root@salotto:/# cd root
root@salotto:~# ls
tbs
root@salotto:~# cd tbs
root@salotto:~/tbs# ls
astra_scan-s2.conf  linux-tbs-drivers.tar.bz2  v4l-cx23885-avcore-01.fw
astra_szap-s2.conf  scan-s2.tar.bz2
linux-tbs-drivers   szap-s2.tar.bz2
root@salotto:~/tbs#
After unzipped
root@salotto:~/tbs# cd linux-tbs-drivers
root@salotto:~/tbs/linux-tbs-drivers# ls
COPYING  INSTALL  linux  Makefile  README  README.patches  v4l
luke81
Re: tbs 6981 new installation on ubuntu 14.04 64 lts
Postby luke81 » Thu Nov 20, 2014 5:17 am
I wrote
./v4l/tbs-x86_64.sh
And I've installed with
# ./v4l/tbs-x86_64.sh
I.4 build and install the driver:
# make && make install
I've rebooted and when I wrote this nothing happens
salotto@salotto:~$ dmesg | grep frontend
salotto@salotto:~$
Is there anybody who can help me?
thanks
luke81
Postby steven » Thu Nov 20, 2014 2:10 pm
Hi luke81
First please make sure that your PC have detect TBS6981
use lspci to have a check.
and you can contact our linux support with email
euro_support#tbsdtv.com
we will reply you as soon as possible.
Postby luke81 » Thu Nov 20, 2014 8:11 pm
this is he output of lscpi
salotto@salotto:~$ lspci
00:00.0 RAM memory: NVIDIA Corporation MCP61 Host Bridge (rev a1)
00:01.0 ISA bridge: NVIDIA Corporation MCP61 LPC Bridge (rev a2)
00:01.1 SMBus: NVIDIA Corporation MCP61 SMBus (rev a2)
00:01.2 RAM memory: NVIDIA Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB controller: NVIDIA Corporation MCP61 USB 1.1 Controller (rev a3)
00:02.1 USB controller: NVIDIA Corporation MCP61 USB 2.0 Controller (rev a3)
00:04.0 PCI bridge: NVIDIA Corporation MCP61 PCI bridge (rev a1)
00:05.0 Audio device: NVIDIA Corporation MCP61 High Definition Audio (rev a2)
00:06.0 IDE interface: NVIDIA Corporation MCP61 IDE (rev a2)
00:07.0 Bridge: NVIDIA Corporation MCP61 Ethernet (rev a2)
00:08.0 IDE interface: NVIDIA Corporation MCP61 SATA Controller (rev a2)
00:08.1 IDE interface: NVIDIA Corporation MCP61 SATA Controller (rev a2)
00:09.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2)
00:0b.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
02:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 210] (rev a2)
02:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
03:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 04)
luke81
Postby luke81 » Thu Nov 20, 2014 10:03 pm
I've removed and then reinstall the card... now when I write this command this is the output:
[   14.393512] cx23885_dvb_register() allocating 1 frontend(s)
[   14.396191] i2c i2c-15: cx24117: Attaching frontend 0
[   14.396199] cx23885 0000:03:00.0: DVB: registering adapter 0 frontend 0 (Conexant CX24117/CX24132)...
[   14.396440] cx23885_dvb_register() allocating 1 frontend(s)
[   14.396449] i2c i2c-15: cx24117: Attaching frontend 1
[   14.396453] cx23885 0000:03:00.0: DVB: registering adapter 1 frontend 0 (Conexant CX24117/CX24132)...
luke81
