OpenELEC Beta 4.95.2 and more
Postby vpeter » Mon Nov 17, 2014 3:28 pm
Latest version:
OpenELEC 5.0.0 TBS Matrix: https://drive.google.com/open?id=0B4FdV ... authuser=0
Old:
OpenELEC-imx6.arm-4.95.2.tar: https://drive.bitcasa.com/send/NMXpCFBA ... 3eKgrk_vj4
vpeter
Re: OpenELEC Beta 4.95.2
Postby steven » Wed Nov 19, 2014 2:18 pm
Hi vpeter
Thanks so much for this new version of Openelec :)
Postby franky384 » Thu Nov 20, 2014 1:32 am
Thank you vpeter,
i'll update soon :!:
franky384
Postby vpeter » Thu Nov 20, 2014 3:05 am
OpenELEC-imx6.arm-4.95.3.tar: https://drive.bitcasa.com/send/i4mMgl7N ... SuNNxv-m5u
With fixed USB detection issue.
vpeter
Postby PeterB » Mon Nov 24, 2014 3:07 am
I was offered an update to 4.95.4 this evening. I presume that your Matrix-specific changes have not yet been merged into the main distribution yet, and that I shouldn't accept the update?
PeterB
Postby vpeter » Mon Nov 24, 2014 3:23 pm
If you update official build everything will still work (I think). But blue led will always blink.
In next days I'm getting cubox-i also and I will check if my changes work without a problem there also. In this case we will get very soon official support in openelec.
vpeter
Postby Ahrlad » Mon Nov 24, 2014 4:08 pm
I have a problem with all recent builds of openelec - earlier I was able to use lsellens repository for sickrage and audo (combined packages of sickbeard, couchpotato, headphones and sabnzbd.) Now I can download the programs but when I try to run them I just get errors that it can't find python distutils. I have tried downgrading to all available versions of openelec in this thread, sadly the ones built before the middle of october seem to have been deleted. Get-pip won't work since /usr/bin is read only. I would be thankful if someone could point me in the right direction!
Ahrlad
Postby vpeter » Mon Nov 24, 2014 5:17 pm
Ahrlad, I don't know what this issue could be. In this regard I didn't add or remove anything.
Can you post little more info? Exactly what you get when running program?
Is this addon works on other openelec systems?
vpeter
Postby Ahrlad » Tue Nov 25, 2014 4:35 pm
Ah, I read his forum posts and it seems that Helix has removed some python dependencies that he has been unable to fix yet. Any chance you could compile a Gotham build with the latest sources? or perhaps reupload a gotham build older than 2014-10-17? The older links no longer work.
Yes, the packages are compatible with other architectures and xbmc versions. He has an own repo that you install through a zip file that is linked at the bottom of his forum posts - just google lsellens. It's extremely useful! Sickpotatohead includes sb,cp and headphones and is strictly for torrents. Audo also includes Sabnzbd for usenet support.
Thanks for your reply! I would love to get my download server up and running again.
Ahrlad
Postby vpeter » Tue Nov 25, 2014 5:32 pm
vpeter
Return to Announcements
