Can you stream channels outside your network
Postby albaniansniper » Sun Nov 16, 2014 12:39 am
Hi Everyone?
I wondering if you can stream channels outside your network to different clients or time zone? Also if so how do you make an m3u8 file or iptv list with tvheadend software?
Many thanks,
Tony
albaniansniper
Re: Can you stream channels outside your network
Postby diabloss » Mon Nov 24, 2014 11:11 pm
Hello Tony .
First of all you have to make sure that MOI IP address and ports are correctly forwarded in your router.
If you using tvheadend 9981 port need to be forwarded
if you using VDR depending on what/which client you using for view your channels over internet.
diabloss
Postby albaniansniper » Fri Dec 12, 2014 5:09 pm
Can you expand a bit on that one? I did forwared the port but cant seem to get it to work?
Can you give an example of what info clients needs outside my lan network.
ip info
port
etc?
Down below are some screenshots of my settings!
port forward
xbmc settings
albaniansniper
Return to MOI+
