How can I get XMLTV module working in MOI+ ?
Postby Sergicchio » Fri Nov 14, 2014 5:44 pm
Hi to all.
I have a MOI+, it's a fantastic device!
I use it as main IPTV and media server in entire house, it drives a lot of frontends flawlessy.
The only cons is a lack of XMLTV integration.
In Italy where I live, over-the-air EPG is poor and often imprecise, either there are channels without ota EPG.
Recording must be input manually following external EPG source.
For repetitive programs also, recording schedule must be configured each day, this is a bit frustrating. (MOI+ has an old 3.9.636~g03a69ff version of TVHEADEND that not support daily recording schedule).
Because I have a place to get everyday a valid XMLTV xml file that contains full EPG data, is there a way to enable MOI's XMLTV module to read epg data from a xml file?
Thanks in advance!
Sergio
Sergicchio
Re: How can I get XMLTV module working in MOI+ ?
Postby Sergicchio » Thu Nov 20, 2014 12:03 am
Solved.
Copied a modified version of TV_GRAB_FILE in /usr/bin, then chmod 755 /usr/bin/tv_grab_file, XMLTV grabber assigned on each channel and it works!
Now I have full EPG on MOI+.
Sergicchio
Postby costan » Tue Feb 24, 2015 11:22 pm
Hello Sergicchio,
can you provide details on how it's working?
I would like to have the same working on my MOI+
costan
Return to MOI+
