tbs5281 cable drivers
Postby evox » Wed Nov 12, 2014 5:35 pm
hello
i have ubuntu 14.04.1 and when i install "./v4l/tbs-x86_64.sh", i don't have any problems with make && make install and my card works with T/T2 but i want cable.
So tryied "./v4l/tbs-dvbc-x86_64.sh" and make with some errors and dmesg don't shows up
root@mythserver:~/linux-tbs-drivers# ./v4l/tbs-dvbc-x86_64.sh
TBS 62xy, 5880 and 528x drivers configured for DVBC (x86_64 platform).
root@mythserver:~/linux-tbs-drivers# make
make -C /root/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/linux-tbs-drivers/v4l'
No version yet, using 3.13.0-32-generic
make[1]: Leaving directory `/root/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.13.0
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.13.0-32-generic/build ./.mycon fig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/root/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/root/linux-tbs-drivers/v4l/firmware'
make -C firmware
CC ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.13.0-32-generic/build
make -C /lib/modules/3.13.0-32-generic/build SUBDIRS=/root/linux-tbs-drivers/v4l modules
make[2]: Entering directory `/usr/src/linux-headers-3.13.0-32-generic'
CC [M] /root/linux-tbs-drivers/v4l/tuner-xc2028.o
CC [M] /root/linux-tbs-drivers/v4l/tuner-simple.o
CC [M] /root/linux-tbs-drivers/v4l/tuner-types.o
CC [M] /root/linux-tbs-drivers/v4l/mt20xx.o
CC [M] /root/linux-tbs-drivers/v4l/tda8290.o
CC [M] /root/linux-tbs-drivers/v4l/tea5767.o
CC [M] /root/linux-tbs-drivers/v4l/tda9887.o
CC [M] /root/linux-tbs-drivers/v4l/tda827x.o
CC [M] /root/linux-tbs-drivers/v4l/au0828-core.o
CC [M] /root/linux-tbs-drivers/v4l/au0828-i2c.o
CC [M] /root/linux-tbs-drivers/v4l/au0828-cards.o
CC [M] /root/linux-tbs-drivers/v4l/au0828-dvb.o
CC [M] /root/linux-tbs-drivers/v4l/au0828-video.o
CC [M] /root/linux-tbs-drivers/v4l/au0828-vbi.o
CC [M] /root/linux-tbs-drivers/v4l/au8522_dig.o
CC [M] /root/linux-tbs-drivers/v4l/au8522_decoder.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-pci.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-usb.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-fe-tuner.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-i2c.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-sram.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-eeprom.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-misc.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-hw-filter.o
CC [M] /root/linux-tbs-drivers/v4l/flexcop-dma.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-driver.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-cards.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-if.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-risc.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-vbi.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-i2c.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-gpio.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-input.o
CC [M] /root/linux-tbs-drivers/v4l/bttv-audio-hook.o
CC [M] /root/linux-tbs-drivers/v4l/cafe-driver.o
CC [M] /root/linux-tbs-drivers/v4l/mcam-core.o
CC [M] /root/linux-tbs-drivers/v4l/cpia2_v4l.o
CC [M] /root/linux-tbs-drivers/v4l/cpia2_usb.o
CC [M] /root/linux-tbs-drivers/v4l/cpia2_core.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-audio.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-dvb.o
CC [M] /root/linux-tbs-drivers/v4l/tbscxci.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-video.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-i2c.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-cards.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-core.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-avcore.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-417.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-pcb-cfg.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-vbi.o
CC [M] /root/linux-tbs-drivers/v4l/cx231xx-input.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-cards.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-video.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-vbi.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-core.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-i2c.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-dvb.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-417.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-ioctl.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-ir.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-av.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-input.o
CC [M] /root/linux-tbs-drivers/v4l/cx23888-ir.o
CC [M] /root/linux-tbs-drivers/v4l/netup-init.o
CC [M] /root/linux-tbs-drivers/v4l/cimax2.o
CC [M] /root/linux-tbs-drivers/v4l/netup-eeprom.o
CC [M] /root/linux-tbs-drivers/v4l/cx23885-f300.o
CC [M] /root/linux-tbs-drivers/v4l/cx25840-core.o
CC [M] /root/linux-tbs-drivers/v4l/cx25840-audio.o
CC [M] /root/linux-tbs-drivers/v4l/cx25840-firmware.o
CC [M] /root/linux-tbs-drivers/v4l/cx25840-vbi.o
CC [M] /root/linux-tbs-drivers/v4l/cx25840-ir.o
CC [M] /root/linux-tbs-drivers/v4l/cx88-dvb.o
make[3]: *** No rule to make target `/root/linux-tbs-drivers/v4l/tbs8921ctrl.o', needed by `/root/linux-tbs-drivers/v4l/tda18271.o'. Stop.
make[2]: *** [_module_/root/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-3.13.0-32-generic'
make: *** [all] Error 2
evox
Re: tbs5281 cable drivers
Postby crazycat » Thu Nov 13, 2014 6:18 am
first run ./v4l/tbs-x86_64.sh
next ./v4l/tbs-dvbc-x86_64.sh
and make
Postby evox » Thu Nov 13, 2014 7:39 am
crazycat Wrote:first run ./v4l/tbs-x86_64.sh
and make
thanks crazycat, you are the man. small steps brings everything runing.
now i need to see how i can install the drivers on my banana pi.
evox
Postby crazycat » Fri Nov 14, 2014 2:44 am
TBS linux drivers only for x86/x86_64 (precompiled binaries)
See open-source alternative implementation for latest TBS devices from Luis Alves
https://github.com/ljalves/linux_media/wiki
Look like 5281 not supported now, but all required code present in official V4L DVB (Si2157/2168 tuner/demod drivers and cx231xx usb controller). So with your help and testing possible make support for your device. And main advantage modern V4L DVB API is multistandard demod support (application also must support standard switch and enumeration).
Postby evox » Fri Nov 14, 2014 8:34 am
crazycat Wrote:TBS linux drivers only for x86/x86_64 (precompiled binaries)
Thanks for the help again. I'm always trying new stuff and learn a little, i can help in testing stuff. if you need someone to test, i'm here.
evox
