install sabre imx6 images os in tbs2910 matrix
Postby fhersete » Sat Oct 25, 2014 4:51 pm
I've been watching you when you install the version of ubuntu linux, comes in a version of sabreauto os firmware imx6, and my question is:
You can use the versions of this website in the matrix tv?
http://boundarydevices.com/imx6-builds/
fhersete
Re: install sabre imx6 images os in tbs2910 matrix
Postby darius75 » Mon Oct 27, 2014 10:46 pm
Hello , same question.
Thanks for your help.
darius75
Postby vpeter » Mon Oct 27, 2014 11:34 pm
Try and see? And then let us know.
vpeter
Postby nwies » Sun Nov 02, 2014 11:40 pm
I just make a successfull try. it's a mix of linux and windows commands
With Linux :
1) download this image:
http://boundarydevices.com/ubuntu-trust ... mber-2014/
2) download also the ubuntu-14.04 test image from TBS
extract both on a temporary directory
we have to dump it on a tar.gz format:
Put it on a sd card :
sudo dd if=20140925-nitrogen-3.10.17_1.0.1_ga-trusty-en_US-lxde_armhf.img of=/dev/sdX
Mount the sdcard ; cd to the mount point ;make the tar archive itself
cd /media/....
sudo tar cvfz "temp_directory/TBS-Matrix-Ubuntu_14.04_V1.0.0.1/Profiles/MX6Q Linux Update/OS Firmware/files/"/trusty_bd.tgz .
edit the ucl2.xml file into TBS-Matrix-Ubuntu_14.04_V1.0.0.1/Profiles/MX6Q Linux Update/OS Firmware
vi ucl2.xml
Replace each "own.tar-x11.gz" with "trusty_bd.tgz"
Nota : If you use a V1.X Matrix version,also replace u-boot-mx6q-sabresd.bin by u-boot-mx6q-sabresd-old.bin
With Windows:
Use the MfgTool2.exe into TBS-Matrix-Ubuntu_14.04_V1.0.0.1 to burn it to the emmc.
The main password (root,ubuntu or sudo) is Boundary
Don't forget to do a apt-get update and apt-get dist-upgrade
Voilà.
nwies
Postby vpeter » Mon Nov 03, 2014 12:21 am
And how does it perform? GPU acceleration working?
vpeter
Postby nwies » Mon Nov 03, 2014 6:17 am
hello,
As described in the BoundaryDevices, I can play the Chromium Acceleration
I still have to figure out the sound subsystem (pulseaudio configuration).
nwies
nwies
Postby vpeter » Mon Nov 03, 2014 3:36 pm
What about mini pcie. Does it work also?
vpeter
Postby fhersete » Mon Nov 03, 2014 4:44 pm
nwies, I knew it worked, you're a machine.
Thank you
fhersete
Postby nwies » Tue Nov 04, 2014 4:18 am
hello everyone.
unfortunatly, the "machine" has a real work...
I can't play with the TBS until friday evening.
Regarding the minipcie, I have some wifi car d to test whith.
I will send any news.
BR
nwies
nwies
Postby fhersete » Tue Nov 04, 2014 4:47 am
When you have time, no rush. In my case I do not care, does not arrive until the weekend, I do not have time for me.
This weekend I will test.
fhersete
Return to Install and setup
