Artifacts when CAM module inserted (also for FTA channels)
Postby jarrebylove » Thu Oct 23, 2014 1:49 pm
Artifacts when CAM module (Cyfrowy Polsat) inserted (also for FTA channels)
I'm trying use TBS5980 to watch pay channels of Cyfrowy Polsat. I have Premium package (full), CAM module and card.
Unfortunately is not works well. I "can watch" encrypted channels, but with some troubles:
1) It's very unstable - sometimes works sometimes not (mostly not).
2) When works, a lots of artifacts appear on to video output (and make it unwatchable).
The artifacts shows on encrypted and FTA channels.
The artifacts shows only when CAM module (with card ofcourse) is inserted. Without CAM module FTA channels works well.
I tested it on several different machines on Linux (Arch Linux x64_86), MS Windows 8.1 and MS Windows 7 (with Service Pack 1) - always with the same results.
I use last posible drivers nad software from your web site.
I checked power supply voltage - is above 7.5 V (on idle and when tuner is tuned to some encrypted channel), so is not to weak power supply problem.
I made tests on different sat sets (different wires, concerters (LNB) and dishes), to exclude weak signal problem - stile with thesame results.
Meybe the TSB5980 hardware is broken and exchange is necesary?
I buyed my tuner from polish distributor dvb24.pl (I live in Poland).
I have no idea to resolve this problem - please help.
dmesg (part)
[ 4245.249023] perf interrupt took too long (2512 > 2495), lowering kernel.perf_event_max_sample_rate to 50100
[ 7260.749526] usb 6-1: new high-speed USB device number 3 using ehci-pci
[ 7262.133041] IR NEC protocol handler initialized
[ 7262.158759] IR RC5(x) protocol handler initialized
[ 7262.183844] IR RC6 protocol handler initialized
[ 7262.212500] IR JVC protocol handler initialized
[ 7262.232045] IR Sony protocol handler initialized
[ 7262.244726] IR MCE Keyboard/mouse protocol handler initialized
[ 7262.276135] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in cold state, will try to load a firmware
[ 7262.299200] lirc_dev: IR Remote Control driver registered, major 248
[ 7262.330557] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5980.fw'
[ 7262.330562] tbsqbox2ci: start downloading TBSQBOX2CI firmware
[ 7262.345338] IR LIRC bridge handler initialized
[ 7262.352382] usb 6-1: USB disconnect, device number 3
[ 7262.452802] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in warm state.
[ 7262.452948] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 7262.452985] DVB: registering new adapter (TBS Qbox DVB-S2 CI USB2.0)
[ 7262.452991] tbsqbox2ci: read eeprom failed.
[ 7262.452996] dvb-usb: MAC address reading failed.
[ 7262.542878] dvb-usb: no frontend was attached by 'TBS Qbox DVB-S2 CI USB2.0'
[ 7262.542890] dvb-usb: TBS Qbox DVB-S2 CI USB2.0 successfully initialized and connected.
[ 7262.543061] usbcore: registered new interface driver tbsqbox2ci
[ 7262.543404] dvb-usb: TBS Qbox DVB-S2 CI USB2.0 successfully deinitialized and disconnected.
[ 7264.099571] usb 6-1: new high-speed USB device number 4 using ehci-pci
[ 7264.224475] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in cold state, will try to load a firmware
[ 7264.224485] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5980.fw'
[ 7264.224489] tbsqbox2ci: start downloading TBSQBOX2CI firmware
[ 7264.342780] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in warm state.
[ 7264.342912] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 7264.343090] DVB: registering new adapter (TBS Qbox DVB-S2 CI USB2.0)
[ 7264.611025] dvb-usb: MAC address: 00:22:ab:c0:2c:be
[ 7264.724923] tbsqbox2ci: Attached stv0903!
[ 7264.725551] tbsqbox2ci: CI initialized.
[ 7264.725671] DVB: registering adapter 0 frontend 0 (STV090x Multistandard)...
[ 7264.800248] stb6100_attach: Attaching STB6100
[ 7264.800548] dvb-usb: TBS Qbox DVB-S2 CI USB2.0 successfully initialized and connected.
[ 7273.291894] tbsqbox2ci: CI enabled.
[ 7273.291905] dvb_ca adapter 0: DVB CAM detected and initialised successfully
[ 7279.466646] traps: blueman-mechani[1145] trap int3 ip:7f3d0adcad00 sp:7fffd89337a0 error:0
[ 7280.083253] traps: blueman-mechani[1149] trap int3 ip:7ffb7068bd00 sp:7ffffca406e0 error:0
[ 7280.975345] hidraw: raw HID events driver (C) Jiri Kosina
[ 7280.984372] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7280.984392] Bluetooth: HIDP socket layer initialized
[ 7281.008275] hid-generic 0005:1131:1616.0001: unknown main item tag 0x0
[ 7281.008425] input: Bluetooth Mouse as /devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.0/bluetooth/hci0/hci0:11/0005:1131:1616.0001/input/input21
[ 7281.008734] hid-generic 0005:1131:1616.0001: input,hidraw0: BLUETOOTH HID v4.10 Mouse [Bluetooth Mouse] on 00:1c:26:f9:d2:8d
[ 7281.075379] traps: blueman-mechani[1155] trap int3 ip:7f35de836d00 sp:7fff720bec80 error:0
[ 7282.022592] traps: blueman-mechani[1188] trap int3 ip:7fa4c62ccd00 sp:7fffd8869390 error:0
lsusb
Bus 006 Device 004: ID 734c:5980 TBS Technologies China
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002: ID 0a5c:2101 Broadcom Corp. BCM2045 Bluetooth
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 064e:a101 Suyin Corp. Acer CrystalEye Webcam
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
uname -a
Linux localhost.localdomain 3.16.2-1-ARCH #1 SMP PREEMPT Sat Sep 6 13:12:51 CEST 2014 x86_64 GNU/Linux
jarrebylove
