Nfs Mount
Nfs Mount
Postby Frankdavies » Wed Oct 15, 2014 3:47 am
I have recently purchased the moi+
i am after some help i would like to record to my nas and i am familiar with nfs mounts.
if i run this command i can manually connect to my nfs mount: mount -o nolock 192.168.1.100:/Recordings /media/Recordings
However if i add this to fstab,so the mount happens automatically on boot nothing happens.
can anyone shed any light on this.
Your help would be very much appreciated
Regards
Frank
Frankdavies
Re: Nfs Mount
Postby Frankdavies » Sat Oct 18, 2014 2:15 am
is this not possible?
if you can find a minute to reply please do.
regards
Frank
Frankdavies
Re: Nfs Mount
Postby diabloss » Sun Oct 19, 2014 2:18 pm
Hello Frank
my question in order to help you out is which backend are you runing on MOI?
Tvheadend or VDR.
If you use Tvheadend you have to access the webui and you have there specific settings for record to an external device.
If you use VDR as backend you will need to edit several config files and fill them in with your settings.
Regards
Ovi
diabloss
Return to MOI+
