Kernel panic when both tuners in use
Postby mitja » Tue Oct 14, 2014 3:12 pm
I was successfully running the device from Ubuntu 13.10 server:
http://www.tbsdtv.com/forum/viewtopic.php?f=85&t=8778&p=30316&hilit=5280#p30316
Currently I am using new hardware and new OS, configuration is as follows.
Hardware:
Intel Core i7-4770S
ASRock B85M-ITX
Crucial Ballistix Sport 4GB DDR3
#lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04 LTS
Release: 14.04
Codename: trusty
#uname -a
Linux encoder1 3.13.0-24-generic #46-Ubuntu SMP Thu Apr 10 19:11:08 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
# lsmod
Module Size Used by
tbs5280fe 18969 2
cx231xx_dvb_ci 22996 0
dvb_core 109932 1 cx231xx_dvb_ci
cx25840 53326 1
cx231xx 173725 1 cx231xx_dvb_ci
cx2341x 28230 1 cx231xx
videobuf_vmalloc 13589 1 cx231xx
videobuf_core 26023 2 cx231xx,videobuf_vmalloc
v4l2_common 16420 3 cx2341x,cx231xx,cx25840
ir_lirc_codec 12898 0
videodev 97660 4 cx2341x,cx231xx,cx25840,v4l2_common
v4l2_compat_ioctl32 16692 1 videodev
rc_rc6_mce 12502 0
lirc_dev 19166 1 ir_lirc_codec
ir_mce_kbd_decoder 12845 0
ir_sony_decoder 12549 0
ir_jvc_decoder 12546 0
ir_rc6_decoder 12546 0
ir_rc5_decoder 12546 0
ir_nec_decoder 12546 0
mceusb 17693 0
rc_core 26933 11 cx231xx,ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,mceusb,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder,rc_rc6_mc
x86_pkg_temp_thermal 14205 0
intel_powerclamp 14705 0
coretemp 13435 0
kvm_intel 143060 0
kvm 451511 1 kvm_intel
crct10dif_pclmul 14289 0
crc32_pclmul 13113 0
ghash_clmulni_intel 13259 0
aesni_intel 55624 0
snd_hda_codec_realtek 61438 1
aes_x86_64 17131 1 aesni_intel
lrw 13286 1 aesni_intel
gf128mul 14951 1 lrw
glue_helper 13990 1 aesni_intel
intel_ips 18664 0
ablk_helper 13597 1 aesni_intel
cryptd 20359 3 ghash_clmulni_intel,aesni_intel,ablk_helper
snd_hda_intel 52355 0
i915 783485 1
serio_raw 13462 0
snd_hda_codec 192906 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 13602 1 snd_hda_codec
snd_pcm 102099 2 snd_hda_codec,snd_hda_intel
snd_page_alloc 18710 2 snd_pcm,snd_hda_intel
mei_me 18627 0
snd_timer 29482 1 snd_pcm
mei 82274 1 mei_me
snd 69238 6 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_pcm,snd_hda_codec,snd_hda_intel
lpc_ich 21080 0
drm_kms_helper 52758 1 i915
soundcore 12680 1 snd
drm 302817 2 i915,drm_kms_helper
i2c_algo_bit 13413 1 i915
video 19476 1 i915
intel_smartconnect 12619 0
mac_hid 13205 0
lp 17759 0
parport 42348 1 lp
hid_generic 12548 0
ahci 25819 2
alx 32452 0
usbhid 52616 0
libahci 32168 1 ahci
mdio 13807 1 alx
hid 106148 2 hid_generic,usbhid
What is happening...I am experiencing a kernel panic when runing mumudvb and connecting to both tuners at the same time. Both tuners work if I run them independently one by one, but not both together.
Suggestions?
Thanks,
Mitja
mitja
Re: Kernel panic when both tuners in use
Postby steven » Tue Oct 14, 2014 4:06 pm
Hi mitja
What about other application such as dvblast ?
Is it the same ?
Postby zhangchao » Tue Oct 14, 2014 4:09 pm
Hi mitja ,
could you send me the configure of mumudvb ?
Best regards !
zhangchao
Postby mitja » Tue Oct 14, 2014 4:31 pm
Here it goes:
# cat udp_mux1.cfg
card=0
freq=522000
srate=27500
autoconfiguration=full
autoconf_ip4=239.100.%card.%number
autoconf_sid_list=1 2 3 5 6 7
# cat udp_mux2.cfg
card=1
freq=570000
srate=27500
autoconf_sid_list=20 21 22 23 24 25
mitja
Postby mitja » Tue Oct 14, 2014 5:08 pm
steven Wrote:Hi mitja
Is it the same ?
Hi steven,
I just installed dvblast and it looks that I am doing something wrong...
My config: mux1.cfg
239.100.0.1 1 1
239.100.0.2 1 2
239.100.0.3 1 3
239.100.0.4 1 5
239.100.0.5 1 6
239.100.0.6 1 7
# dvblast -a 0 -c mux1.cfg -f 522000000 -m qam_64 -b 8
DVBlast 2.2 (git-2.2-73-g71736aa)
warning: restarting
debug: compiled with DVB API version 5.10
error: unable to query frontend
# dmesg | grep frontend
[ 12.912869] DVB: registering adapter 0 frontend 0 (TurboSight TBS 5280 DVBT/T2 frontend)...
[ 13.083651] DVB: registering adapter 1 frontend 0 (TurboSight TBS 5280 DVBT/T2 frontend)...
Any ideas why it reports unable to query frontend?
Br,
Mitja
mitja
Postby vpeter » Tue Oct 14, 2014 6:50 pm
mitja Wrote:Any ideas why it reports unable to query frontend?
Mumudvb running at the same time?
vpeter
Postby mitja » Wed Oct 15, 2014 3:48 am
Nope ;)
mitja
Postby apache » Wed Dec 31, 2014 12:45 am
I have simmilar problems with my TBS5280, but I use tvheadend. Everything is fine when I'm using one tuner. When I'm using both tuners -after few times everything is hanging up with a lot of "UsbInterface::sendCommand, failed with status --19" and other stuff (like xhci errors)... When I disable one tuner everything work fine...
Does anybody knows how to fix that?
apache
Postby Souldream » Sun Mar 13, 2016 1:26 am
Is it the same ?
Hi steven,
My config: mux1.cfg
239.100.0.1 1 1
239.100.0.2 1 2
239.100.0.3 1 3
239.100.0.4 1 5
239.100.0.5 1 6
239.100.0.6 1 7
warning: restarting
Br,
Mitja
When will you go on 5.10 for Real ?
Souldream
