BBframe headers and GSE headers
Postby Midwestmac » Tue Sep 30, 2014 11:46 am
Hello I've been recording some GS continuos ACM/VCM signals with the latest TBS recorder. Using TBS 6925 with WIn xp.
I think I have been getting some good recordings with a few errors at the very end of my recordings, but can never get a recording larger than 400mb with out errors.
I was wondering if anyone else is having better success in Windows or Linux?
Also would it make a difference to have a Solid state drive to do recordings?
Would like to here some feedback thanks
Midwestmac USA
Midwestmac
Re: BBframe headers and GSE headers
Postby Midwestmac » Wed Oct 01, 2014 10:49 am
A friend wrote small program to check recording for errors, Thought I'd share.
Using TBSrecorder Here is beginning of my recording the first BBF is @ line141. You can see the Matype is 4200
BBF @ 141 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2938 SYNC=$CD SYNCD=$0000 CRC1=$58
BBF @ 1470 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$CE SYNCD=$0000 CRC1=$3F
BBF @ 2934 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$CF SYNCD=$0000 CRC1=$BC
BBF @ 4398 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$D0 SYNCD=$0000 CRC1=$60
BBF @ 5862 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2938 SYNC=$D1 SYNCD=$0000 CRC1=$D4
BBF @ 7191 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2930 SYNC=$D2 SYNCD=$0000 CRC1=$D3
BBF @ 8519 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$D3 SYNCD=$0000 CRC1=$30
BBF @ 9983 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$D4 SYNCD=$0000 CRC1=$13
BBF @ 11447 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$D5 SYNCD=$0000 CRC1=$90
BBF @ 12911 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$2D70 SYNC=$D6 SYNCD=$0000 CRC1=$C0
Then ::Towards the end of my recording I lose SYNC and so the MATYPE 4200 do not all line up were they should
BBF @ 477555125 MATYPE=$414E [GS-C MIS ACM ISSYI=0 GLT=0 RO=1 ISI=$4E] UPL=$4369 DFL=$4167 SYNC=$4E SYNCD=$4449 CRC0=$35
BBF @ 477557227 MATYPE=$4BF4 [GS-C MIS ACM ISSYI=1 GLT=0 RO=3 ISI=$F4] UPL=$2F15 DFL=$71B0 SYNC=$84 SYNCD=$0BAD CRC0=$28
BBF @ 477560875 MATYPE=$AE7B [GS-HE SIS ACM ISSYI=1 GLT=1 RO=2 ISI=$7B] UPL=$7302 DFL=$81B9 SYNC=$CD SYNCD=$5847 CRC0=$4D
BBF @ 477565036 MATYPE=$9604 [GS-HE MIS CCM ISSYI=0 GLT=1 RO=2 ISI=$04] UPL=$D80F DFL=$8FA2 SYNC=$6D SYNCD=$460E CRC0=$2F
BBF @ 477569642 MATYPE=$76F1 [GS-C SIS CCM ISSYI=0 GLT=1 RO=2 ISI=$F1] UPL=$20F9 DFL=$1CC4 SYNC=$14 SYNCD=$3486 CRC0=$E8
BBF @ 477570572 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$01A0 SYNC=$B5 SYNCD=$0000 CRC1=$DB
BBF @ 477570634 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$0080 SYNC=$00 SYNCD=$0000 CRC1=$F7
BBF @ 477570660 MATYPE=$4200 [GS-C MIS ACM ISSYI=0 GLT=0 RO=2 ISI=$00] UPL=$0000 DFL=$0080 SYNC=$00 SYNCD=$0000 CRC1=$F7
Midwestmac
Postby Midwestmac » Wed Oct 01, 2014 12:14 pm
Oh I forgot here is a link to another post I started and what I think might be my problem.
http://www.tbsdtv.com/forum/viewtopic.php?f=25&t=8881
Midwestmac
Postby Midwestmac » Thu Oct 02, 2014 1:16 pm
Here is a pic with hex editor.
I highlighted in blue the beginning of 10 byte bbheader
in red is the 7 byte GSE header which has a 6 byte label
in orange is the encapsulated Ts packets 470800 which all line up at 188 bytes.
This was a good recording if I could just get a longer recording though. I think I have good signal here.
Midwestmac
Return to General discussion
