help install tbs6982 in ubuntu-14.04.1 server
Postby riadh2010 » Sun Sep 28, 2014 5:41 pm
hi all
i look it every were how to install tbs6982 on ubuntu-14.04.1 server i cant find any,
can some one help me with commands to install it please
thanks
riadh2010
Re: help install tbs6982 in ubuntu-14.04.1 server
Postby vpeter » Sun Sep 28, 2014 6:01 pm
vpeter
Postby riadh2010 » Mon Sep 29, 2014 3:14 am
i did try it didnt work fore me
riadh2010
Postby riadh2010 » Mon Sep 29, 2014 5:15 am
any one can help with commands to install it please
riadh2010
Postby vpeter » Mon Sep 29, 2014 2:31 pm
Those commands works. If you post what did you do you would get more help. You can't say "it didn't work". What if you made mistake when typing commands. And you do have instructions in file README_TBS6981 in drivers zip file.
vpeter
Postby riadh2010 » Tue Sep 30, 2014 5:05 am
wen i put this command
mv dvb-fe-cx24116.fw /lib/firmware/
i get this
pike@pike:/root/tbs$ mv dvb-fe-cx24116.fw /lib/firmware/
mv: cannot stat ‘dvb-fe-cx24116.fw’: No such file or directory
wen i go to lib then firmware i find this file on the dvb-fe-cx24116.fw
tar xjvf linux-tbs-sources.tar.bz2
i get this
pike@pike:/root/tbs$ tar xjvf linux-tbs-sources.tar.bz2
tar (child): linux-tbs-sources.tar.bz2: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
can you tel me what i am doing wrong
riadh2010
Postby franky384 » Wed Oct 01, 2014 8:56 pm
1. When you have the firmware file in /lib/firmware/ you don't need to move it here.
2. Do you have the file linux-tbs-sources.tar.bz2 ? Change in the directory where the file is located and type the command again.
franky384
Postby riadh2010 » Tue Oct 07, 2014 1:39 am
i give up on it at the mow i tryed every thing i found on internet no joy no thing work for me :( :(
riadh2010
Return to Install and setup
