install tbs 6281 on ubuntu 14.04 x86
Postby jim85 » Fri Sep 05, 2014 3:28 pm
IFirst thing, i'm a newbie on linux.
I bought a tbs 6281 pcie card for my htpc
I tried many times to install it but nothing works.
Here is the code I used to install it :
mkdir driver
cd driver
wget http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v140819.zip
unzip tbs-linux-drivers_v140819.zip
cd linux-tbs-drivers
sudo ./v4l/tbs-x86.sh
sudo make && sudo make install
sudo shutdown -r now
I found this code on web.
The code never returns errors, but nothing change.
Please, helpe me.
Jim
jim85
Re: install tbs 6281 on ubuntu 14.04 x86
Postby vpeter » Fri Sep 05, 2014 4:38 pm
TBS doesn't provide tuner drivers for arm. I think you are out of luck.
The only option is to use opensource drivers: https://github.com/ljalves/linux_media/wiki
Didn't test them yet.
vpeter
Postby jim85 » Fri Sep 05, 2014 4:44 pm
Thanks for your answer but what is arm?
I installed it yet but not working.
jim85
Postby vpeter » Fri Sep 05, 2014 4:57 pm
Why are you then writing under section for ARM base computer Matrix ARM mini PC (TBS2910)?
vpeter
Postby jim85 » Fri Sep 05, 2014 5:09 pm
Sorry but I don't know how to select he good section...
jim85
Postby vpeter » Fri Sep 05, 2014 5:37 pm
jim85 Wrote:I tried many times to install it but nothing works.
Without further infos no one can help you. And my crystal ball is broken.
You got any errors when compiling the driver?
vpeter
Return to Install and setup
