TBS MatrixTV system update to V1.0.1.0
Postby steven » Thu Sep 04, 2014 3:58 pm
Hi All
TBS MatrixTV system has been updated to V1.0.1.0 with following improvements:
News:
1.Add TBSIPTV support when using tvheadend,more information please read this pdf file.
http://www.tbsdtv.com/download/document/iptv/How_to_setup_easy-to-use_IPTV_with_MOI+-MOIPro-Matrix.pdf
with this you can easy setup a simple IPTV system. :)
2.Update to latest wolfgar's XBMC
3.Update to latest vdr
4.Fix some small bugs
There will be two version of firmware one is for the older version one is for the new version.The different is the memory chip.
For older matrix version:
MFG Tools burn:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.1.0.zip/download
For V2.1 matrix version:
MFG Tools burn:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.1.0-V21.zip/download
kind Regards
Re: TBS MatrixTV system update to V1.0.1.0
Postby elbandido » Tue Sep 09, 2014 9:32 am
The older version will not load on my older Matrix!
Twice I have downloaded the file and tried to load it.
The file starts loading correctly, but finishes in less than a minute without installing.
elbandido
Postby vpeter » Tue Sep 09, 2014 2:37 pm
There is an error in this image - only updates kernel without root filesystem. Open file cfg.ini and change
name = SabreSD-eMMC-kernel
to
name = SabreSD-eMMC
Then install again.
vpeter
Postby elbandido » Wed Sep 10, 2014 4:12 am
Very Good!
Making the changes you suggested worked.
elbandido
Postby javanphi » Fri Sep 12, 2014 4:03 am
hello,
With this version I can not select the audio output in XBMC, the option is grayed out?
Any idea?
thank you
javanphi
Postby mikebzh44 » Tue Oct 21, 2014 2:36 pm
I'm trying MatrixTV 1.0.1.0 and OpenELEC Gotham before making my choice.
When configuring matrixTV by pressing key whithin 3 first second after boot, I'm entering the configuration menu.
I switch language to French but when running XBMC, physical keyboard is still with QWERTY layout.
When running OpenELEC, there is an OpenELEC configuration addon and you can configure AZERTY layout.
How can I set keyboard to AZERTY on MatrixTV 1.0.1.0 ?
Thanks.
mikebzh44
Return to Announcements
