Clients for MOI+
Clients for MOI+
Postby oddity » Fri Aug 15, 2014 3:05 am
Would be interested in what clients and setups people are using with the MOI+ and how stable they have been.
oddity
Re: Clients for MOI+
Postby elchubi » Fri Aug 15, 2014 10:04 am
Using
Webpage
VLC
DVBLINK (iptv plugin)
All three very stable with firmware 1.0.1
elchubi
Postby oddity » Sat Aug 16, 2014 2:14 am
Interesting. I take it you are using Tvheadend on the MOI+, then using Dvblink to connect as a Client using the DVBlogic Server and IPTV modules.
Tvheadend is easily set up, but channel configuration on the DVBLogic software is a bit of a pain, how did you find this? Also does it pass the EPG information through correctly?
oddity
Postby elchubi » Sat Aug 16, 2014 6:17 pm
I'm using vdr not tvheadend because it worked better for me on v1.0.0, now on v1.0.1 they work the same but I got used to vdr
Vdr provides m3u file direct to dvblink iptv, so for channel config I didn't do any extra stuff except for EPG, I use mc2xml and I had to map channel by channel but it was easy and one time thing
I could have use an script for converting vdr epg to xml and avoid the channel by channel map but in my case mc epg have more information than eit one
elchubi
Postby oddity » Sat Aug 16, 2014 7:26 pm
Thanks, not tried vdr.
I know from the moi webpage you can scan for channels for vdr.
Is there a web front end for vdr?
A getting started with VDR wold be most helpful.
What is the url for the m3u file for dvblogic?
Any info appreciated.
oddity
Postby elchubi » Sun Aug 17, 2014 12:05 am
http://{ip of your moi+}:3000
You can get the m3u from a link at that webpage (channels / playlist)
elchubi
Postby elchubi » Sun Aug 17, 2014 12:08 am
http://{ip of your moi+}:3000/channels.m3u
elchubi
Postby oddity » Sun Aug 17, 2014 2:18 am
Cheers, VDR is working so much better then TVheadend, could not get it working very well at all. VDR straight away and much more reliable.
oddity
Postby elchubi » Sun Aug 17, 2014 5:08 am
Glad to help
Just for curiosity, in which country are you?
elchubi
Postby oddity » Sun Aug 17, 2014 3:40 pm
I'm in the UK.
oddity
Return to MOI+
