Network problems on Android : No ethernet, Wifi Out of range
Postby ccatwo » Wed Aug 13, 2014 8:19 pm
Dear All,
I have some problem with networking on android.
  • I can't find any option to configure ethernet port :
    Is there any support for ethernet in the Matrix TBS android distribution
    I have tried with version TBS-Matrix-Android-JB-4.2.2-V2 and TBS-Matrix-Android-JB-4.2.2-V3
  • The wifi seems unstable :
    I can scan wifi APs.
    When I select my AP and enter the key, it starts to connect with : Authenticating, Getting IP address and then shows Out of range.
    I have tried with another AP (my android phone as AP (Galaxy S2))
    I have tried changing the channels and wifi mode
    but I always get Out of range.
Is anyone using android on the Matrix TBS having such issues with the network ?
Thank you in advance for your help.
ccatwo
Return to General discussion
